Taco15
I wear stretchy pants
OK... so you arent going all motor well you might to shoot for alittle higher hp to get you in the 11's. ohh and ditch the obd 0 and get you a p28. better tuning optionstypej said:Just so that you guys get a better understanding of my goals:
1987 Honda CRX Si
JDM (OBD 0) B16a
B20 Block
turbocharged (full-race.com stage 1 kit) 300 whp
Possibly with a 4.05 final drive ratio.
At the moment, I'm basically refreshing the internals of the motor (piston rings, main bearings, replacing, etc.) because I have just received it.
Oh, by the way, did you know that the K24 motor is the same price as my complete swap, minus the axles, but the Hasport motor mounts are about the same price.
I know that it doesn't have much for torque, but in an 1800 lb. chassis that's stripped, I believe I have a greater advantage than some of the stock b16 cars.
soryy just read that you got a obd0 b16. oops. I thought you planned on staying obd0. my bad. still make sure you get a good tune
