87 Crx Swap
Discussion in 'HYBRID -> EG-EK / DC' started by psysfdd, Mar 2, 2003.
  1. psysfdd
    psysfdd Junior Member
    I have an 87 crx si, i want to do an engine swap. what would you all recomend? or should i just sell it and get a 2nd gen crx? thanks.
  2. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    It will be easier to do the swap into a 2nd gen rex.But if you like it than all the issues can be worked around.A B16A in a 1st gen is lethal though.
  3. whatdahieu
    whatdahieu Senior Member
    1.engine swap off a 86-89 teg directly bolts in
    2.head, intake manifold, fuel rail, throttlebody bolt on to block off 86-89 teg
    3.92-95 ex/si head bolts directly to block
    4.hasport motor mounts, axles, shift linkage,motor, cable tranny for b series
    1.http://hybrid2.honda-perf.org/tech/3gtech.html
    2. http:www.hondaswap.com/articles/viewer.php?id=24
    3.http:crx.honda-perf.org/articles/z6swap/z6swap.html
    4.www.hasport.com
    if you care about body kits
    1.www.housemanautosport.com
    2.www.andysautosport.com
    3.www.extremedimensions.com
    4.www.grounddynamics.com
    5.www.rtautosports.com
    and if you want a rear disk brake conversion
    1.http://coreyonline.tripod.com/integradiskbrake.html
    clear corners
    1.www.crown-honda.co.uk/parts/index.htm
    clear turn signals
    1.84-88 toyota after market pickup truck turn signals :D hope this helps
