87 DOHC ZC in a 89 Si
Yspeed
Member
Well I have the 87 ZC in my 89 hatch, I went to start it and the starter just spins. What starter do I have to use to get it to hit the flywheel?
i would get a different flywheel...what trans are you using? if you are using the one from the hatch the starter wont reach on the teg motor
and why do you have that motor in there?
Well I'm using the Si tranny, I didn't know It was a 87 till I went to the shop to get my distrubutor check out and he told me It was from a 87. Well I have the motor in there I'm not going to take it out and put a new flywheel in, I just need to find a bigger ping. I'm sure the starter is working it's just not long enough to hit the flywheel. I was think could I use the teg one or just get my pin bigger. It's all wired up so there's no way it's coming out. Thanx for the help
