87 Integera engine into 89 CRX Si ???
Discussion in 'HYBRID -> ED-EF / DA' started by movintons, Jan 20, 2005.
  1. movintons
    movintons Junior Member
    My friend has a 89 CRX Si with a trashed d16a6 engine. We want to replace it and have found an 87 Integra with a d16a1. Will this be a straight swap or will it work at all? If not what are our best options? He is working with a very thin wallet and needs the car to get to work so this is a consideration.
    Sorry if this has been answered before, I did a search and couldn't find the information.
    Thanks
  2. reckedracing
    reckedracing TTIWWOP VIP
    NY
    B16 or D16? huge diffrence
    D16a1 will offer almost no gains from a stock replacement motor and i think it will not be a direct bolt in as that motor bolts into a first gen crx...
    thin wallet = stock replacement for 100 bucks
  3. movintons
    oops...
    the motor in the CRX is a d16a6...the integra is a d16a1 (twin cam)
    I wish I could find a d16a6 for a hundred dollars. Every thing I have found is 600.- 700 dollars.
    I found the d16a1 integra motor for 350. but didn't know if it would work.
  4. reckedracing
    NY
    that motor will not bolt to your trans
    look around, people throw those si motors in the garbage cause they aren't worth dick
  5. movintons
    I have called junk yards in Huntsville, AL and the going price there seems to be in the $500.00 area.
    The friend is my girlfriends son and I might get special favors if I help him. LOL
    He paid way too much for a car that didn't run. The head gasket was blown and the head is erroded in the water jacket area. Is there anything I can do to salvage the head? Is there another head that I should look for to save his engine?
    Any help you can give is appreciated. Sorry, I can't share the special favors I get from his mom.
  6. reckedracing
    NY
    replace the head gasket and put the head back on...
    if you;re worried about warpage then get the head milled...
    you can use just about any d series head on this block, if you want performance look into doing a mini-me sohc vtec head swap...
    say what?!?!?
    thats kind of disturbing
    lol
    helping her son to get the nookie...
    her son must be at least 16, so that makes her what, 35ish?
    so i'll just assume that you are either young and just l-l-love the milfs, or are older yourself...
    search this forum, or honda-tech, or any other honda variation, you will definately find someone in your area that ripped this motor out to drop in a better one...
    you can relap the valves, get the head milled, and replace the valve seals and then it should be just as good as new, and just clean out the water jackets, this should not be a problem...
  7. movintons
    The concern is not warpage...the head is erroded in the area outside of where the sleaves seat. I have never seen this before but would think it was a problem. If you look at the flat side of the head it has trenches erroded into in the area outside and up to the sleave sealing area. normal???
    The milf is more like 45 but she is a hottie. :eek:
  8. PhyRe
    PhyRe Senior Member
    ct
    now what do you get if this son of hers crashes the car? that a def no play. i wouldnt go in to prefornance
  9. movintons
    This has already happened before with her motorcycle. Then I am the shoulder to cry on. LOL
  10. reckedracing
    NY
    so how old are you?
    you gonna post some pics up?
    and the erroded area goes all the way to where the head meets the sleeve??
    if so and its obvious the head will not seal with the block correctly then you can;t use it of course... but i have never seen that...
    can you post a pic of the head?
