'87 Prelude - Cylinder Head Dimensions
Z-gear
How can I get the minimum allowable head thickness for my '87 'Lude.
It was milled and I want to know the stock thickness and minimum allowable thickness as measured from "valve cover deck" down to "block deck surface".
I'm sure this will get moved to wherever it needs to go. But before that happens...
Go to 3geez Forums The 87 Lude 2.0si (which I assume you have) shares the same motor as the Accords.
We'll get you straight over there :)
