87 REX Si head swap
Discussion in 'HYBRID -> ED-EF / DA' started by racintweek, Mar 25, 2004.
  1. racintweek
    racintweek Senior Member
    Arlington VA
    will a 91 rex si head fit on a d15a3 block from an 87 rex si
    also will the 91 si trans bolt up to 87 si block?
  2. daidilus
    daidilus Member
    no
    and ummm no
    but i do hear that a d16a1 DOHC head would work on a EW block
    and the d16a1 from the 86-89 integra will fit your car
    www.redpepperacing.com
  3. racintweek
    Arlington VA
    what is involved with putting the d16a1 in to the 87 rex si?
  4. 91CRXSI
    91CRXSI Member
    I have a swap for your rex, i had a 86 Si, traded it away for another rex then got it back, I put a D16a1 DOHC motor, Intera tranny and axels, Integra Spindles, Integra shift linkage, integra computer, and needed match on mounts, you can make an offer for the swap. Putting the motor in wasnt that bad, i did it in a weekend. including pulling motors out of both integra and crx. It will bolt right in using the driver side and rear mount from the crx and the passenger side mount from the integra. on the driver side mount a little notch must be made on the mount to clear the timing belt cover, nothing serious, only like a 1/4 inch. aslo the is no plug on the SI harness( the one you must use) for the IAC(idle air controller). other than that it is an easy swap, after swap BE SURE to get an alignment, the toe arms on the integra spindles ar angled in more than the crx ones, it will put you toe in approx 3", it will chew a set of tires in no time. e-mail me or post reply, where are you located and if you are interested in the swap, also that swap was very impressive, i only raced it once against a 2000 Si and blew its doors off.
  5. reckedracing
    reckedracing TTIWWOP VIP
    NY
    lol
    i learned the alignment hint the hard way
    i also did this swap so PM me questions if need be
    its pretty easy
    i have 2 crx si motors, 2 si trans, and an si computer if anyone needs them...
