87civic swap problem
Discussion in 'Civic and CRX - EW' started by civicjunky, Oct 4, 2006.
  1. civicjunky
    civicjunky New Member
    i put a 87 integra dohc zc in my 87 civic and now she doesnt want to run right do i need to change out my stock si ecu with a integra ecu?
  2. ef8
    ef8 Junior Member
    Whats the problem?
  3. civicjunky
    she seems to be running real rich and she misses when i excelerate so im thinking the air fuel is off
  4. ef8
    ef8 Junior Member
    Is the timing good?
  5. civicjunky
    ya i have also checked map sensor and she also is belching black smoke so i did a compression ckeck and the lowest cylinder is 130 and the highest is 160. i am running on the stock si ecu
  6. ef8
    ef8 Junior Member
    Is there an aftermarket fuel pressure regulator?
  7. ef8
    ef8 Junior Member
    also have u tried putting in the pg7 ecu?
  8. civicjunky
    i put an aftermaket regulator in after the problems thinking it would help but it didnt help.what does thr pg7 come out of?by the way i appreciate the help.
  9. jlicrx
    jlicrx Senior Member
    Colorado Springs
    PG7 is from 86-89 Integra - you need 86-87 PG7 which is different from 88-89 PG7
    86-87 PG7 looks like this:
  10. civicjunky
    do you think that will take care of my problem?
