you can swap all the parts on to your existing axle. you will need: integra LH,RH hubs, the integra bolts that mount the hub to the axle(the bolts are longer then the civics/crx ones), intgera LH,RH E brake cables,backing plates, calipers, rotors, pads, caliper mounts. NOT sure if 13s fit over them i do know 14s do.
