7 7thgen01 Member Apr 23, 2003 #1 ive got a 91 crx si with the factory D series motor. will the flywheel in the crx work in the 97 dx transmission, since they are both D series motors.
E_SolSi Member of the 20 nut club Moderator VIP Apr 23, 2003 #3 the flywheel should mount up ok but it is smaller so you will need to use the clutch and pressure plate for the CRX as well
