88 CRX DX Fuel Injection Problem
Discussion in 'General Tech and Maintenance' started by CRX-Fluffy, Oct 3, 2003.
  1. CRX-Fluffy
    CRX-Fluffy Junior Member
    Hey wasup peeps. I'm new to the board :cool: . I was wondering if you guys could help me. See heres the problem.
    I have an 1988 CRX DX w/ exhaust and intake using the stock DPFI (Duel point fuel injection). The car starts fine in the morning and I can roll fine. Except, sometimes the car starts revving between 2000-3000 rpm (Or just stays at 3,000 rpm) w/o pressing the pedal. Hence, It revs when Im just sitting there. As it does that, I can smell gas fumes coming from my exhaust and black build up all over the inside (Im guessing its carbon forming from burning gas). Also when It revs I lose throttle control. For example, every time I press the pedal instead of making the car go it just stops it. Kinda of weird. I have posted on other boards, but I cant figure out the problem.
    -I have replaced the O rings on the Fuel Injectors
    -Cleaned out the Fuel system with Fuel Injector cleaner
    Rarely, does it rev up to 3,000 rpm then back down and gives me a check engine light. But this problem is wasting 50 miles of gas mileage. If you can help I'd appreciate it greatly!
    My Contact info:
    AIM: NeophyteEQ
    EMAIL: Fluffycabbage@tranceaddict.net
    If your in the LBC area, I'd be happy to drive over there.
