'88 Crx Weights
Discussion in 'Members' Lounge' started by crxyz, Feb 5, 2003.
  1. crxyz
    crxyz Junior Member
    ..Just wondering what Honda deleted off the '88 HF that makes it 200 lbs lighter than '88 Si. i understand no sunroof and nothing in the front bumper, but what else is different/ can be taken out/ changed? More lightness equals more performance.
  2. zueke
    zueke Senior Member
    Lansing, MI, USA, Earth...
    Power steering, A/C, rear disk brakes(?), more sound insulation inside the body panels.. Stuff adds up quick.
  3. crxyz
    crxyz Junior Member
    It's an '88 Si with manual steering, no A/C and drums in the back, (and a radio block off plate from the factory) maybe a part of the difference on the specs is figuring that most people would get A/C on the Si and not on the HF? I'll just have to weigh the car some time and see where it really is to start, thanks.
  4. Jeef
    Jeef NO MA'AM Moderator VIP
    www.crx.org and go to the resource. They have a lot of the reasons why.
  5. sportlinecrx
    sportlinecrx Banned
    here is a link to quickhonda.net. in "the garage" section, you will find a section called "2nd gen differences". that site is dedicated to the crx.
    http://www.quickhonda.net/index2.htm
    the wieght differences are basically due to the SI coming standard with:
    A/C, beefed-up suspension (thicker sway bars, anti-roll bars), larger engine, radio, speakers, sunroof, right side mirror, floor mats, cargo cover assembly (that alone wieghs like 15-20lbs)
    the HF did not come with any of that.
