88 Crx
Discussion in 'HYBRID -> EG-EK / DC' started by honda boy, Jan 17, 2003.
  1. honda boy
    honda boy Junior Member
    I need some help if any one could give me some ideas i have a 88 crx i wanted to do a h22 swap in it but alot of peeps are saying not worth it unreliable breakin down alot. would a gsr motor be a better way to go any sugestions would be greatly appreciated
    thanks
    What about the B18a or whats the difference between the b18c?
  2. prawjEKt Cx
    prawjEKt Cx Senior Member
    upstate NY
    yeah i would always suggest a b18c over a h22 in a civic chassis
  3. MaaseyRacer
    MaaseyRacer Senior Member
    San Francisco, Ca.
    If you have a lot of time and a lot of money or just the desire to put an h22 in your crx then I would say go for it. otherwise, the b18C is a way easier swap, and there are many kits to put it into your car.
    Good Luck man...
  4. ef6-ef8
    ef6-ef8 Junior Member
    time & money-->h22
    lil bit easier-->b18 or b16
    try and get a hold of a tranny off a 88-91SiR its cable not hydro.
    the b16a1 has the cable tranny on it but the tranny will fit on the b18
  5. honda boy
    what about the B18a is it better then the b18c? whats the difference between the 2?
  6. MaaseyRacer
    San Francisco, Ca.
    the B18A is a non vtec version, look into that if you want to go turbo, otherwise if you want all motor check out the B18C it is VTEC, and will make a fast ass CRX.
  7. skunk2crx
    skunk2crx Junior Member
    Southern California
    I think that is is all about what you want your car to be. If you just want to drag, go h22. That is the holy grail of honda 4-cylinder engines. however, if you are looking for daily driveability with mad power, you should go b16a, b18c, b18a/b with /b16a (ls/vtec) or even b18c5 if you have the money. I have a b16a 5 series in my crx with an lsd tranny and it hits hard. it's all about time and money.
  8. Domeskilla
    Domeskilla Senior Member
    Fort Wayne, IN
    You can get a h22a in there, do a cable/hydro tranny conversion from HASport and then beef up the suspension. You can daily drive it, you just can't take corners like a crx with a b series in it. You wont ever be competitive in autox.
    I suggest a cable.hydro conversion period. The b16 cable tranyn blows, if you want to go all motor, i would do the conversion, get an itr tranny.
