88+ ECU Error Codes
Discussion in 'Reference Materials' started by pissedoffsol, Jan 12, 2004.
  1. pissedoffsol
    ECU Error Codes
    Here's a handy chart for pulling your ECU codes. Pulling the code is a fairly easy process.
    For 92+ Honda's and 94+ Acura's:
    Before you can start reading the CEL (check engine light) in your dash, you need to 'jump' your ecu. Here's how.
    Located the factory two-pin connector of brown and black wires near the ECU on Civics del Sols and Integra's, or behind the center console for Preludes and Accords. Pull that 2-pin out of the main harness. Using a wire or paper clip as a jumper, connect the outputs of the harness together, so that the black wire and the brown wire make a circuit. Once this is jumped together, the dash will start the light show, so its a good idea to jump first, then turn to on.
    For 88-91 Honda's and 86-93 Acura's:
    The ECU's on these cars actually have a neat little window right on the computer case. No need to jump here- just turn it to on, and watch it right there through that window.
    For both steps above, the output will be in a Morse code style of long and short lights. For example, 2 long, pause, 3 short is 23.
    1- Accord Civic CRV CRX Del Sol Odyssey Prelude
    85-98 86-98 97-98 85-91 93-97 95-98 85-98
    Oxygen Sensor "A" (Primary)
    defective circuit or unplugged / defective sensor
    2- Accord Civic CRV CRX Del Sol Odyssey Prelude
    85-89 86-87 n/a 85-87 85-91 n/a n/a
    Oxygen Sensor "B"
    3- Accord Civic CRV CRX Del Sol Odyssey Prelude
    MAP Sensor (Manifold Absolute Pressure)
    4- Accord Civic CRV CRX Del Sol Odyssey Prelude
    90-98 88-98 97-98 88-91 93-97 95-98 85-98
    CKP Sensor (Crankshaft Position Sensor)
    5- Accord Civic CRV CRX Del Sol Odyssey Prelude
    85-98 * 86-98 97-98 85-91 93-97 96-98 85-98
    mechanical problem / disconnected piping
    * exc 94-95
    6- Accord Civic CRV CRX Del Sol Odyssey Prelude
    ECT Sensor (Engine Coolant Temperature)
    7- Accord Civic CRV CRX Del Sol Odyssey Prelude
    TP Sensor (Throttle Position)
    8- Accord Civic CRV CRX Del Sol Odyssey Prelude
    TDC Sensor (Top Dead Center)
    9*- Accord Civic CRV CRX Del Sol Odyssey Prelude
    85-98** 86-98 97-98 85-91 93-97 95-98 85-98
    CYP Sensor (Cylinder)
    * not a valid code for any throttle body injection Hondas
    ** not a valid code for V-6 engines
    10- Accord Civic CRV CRX Del Sol Odyssey Prelude
    IAT Sensor (Intake Air Temperature)
    12- Accord Civic CRV CRX Del Sol Odyssey Prelude
    85-98 86-98 * n/a 85-91 * n/a 95-98 85-98
    EGR Lift Sensor (Exhaust Gas Recirculation)
    * not a valid code if car is not equipped with an EGR valve (some Civic models are not)
    13- Accord Civic CRV CRX Del Sol Odyssey Prelude
    BARO Sensor (Atmospheric Pressure)
    14- Accord Civic CRV CRX Del Sol Odyssey Prelude
    88-98 88-98 97-98 88-91 93-97 95-98 88-98
    IAC Valve (Idle Air Control)
    15- Accord Civic CRV CRX Del Sol Odyssey Prelude
    90-95 88-95 n/a 88-91 93-95 95 88-95
    Ignition Output Signal
    missing or defective ignition output signal
    16- Accord Civic CRV CRX Del Sol Odyssey Prelude
    Fuel Injector System
    defective circuit or unplugged / defective fuel injector
    17- Accord Civic CRV CRX Del Sol Odyssey Prelude
    88-98 88-98 97-98 88-91 93-97 95-97 88-98
    VSS (Vehicle Speed Sensor)
    19- Accord Civic CRV CRX Del Sol Odyssey Prelude
    n/a 88-95 n/a 88-91 93-97 n/a n/a
    Automatic Transmission Lock Up Control Solenoid Valve
    defective circuit or unplugged / defective solenoid valve
    20- Accord Civic CRV CRX Del Sol Odyssey Prelude
    90-98 88-98 97-98 88-91 93-97 95-98 92-98
    Electrical Load Detector
    21*- Accord Civic CRV CRX Del Sol Odyssey Prelude
    94-98 ** 92-95 n/a n/a 93-95 n/a 93-95
    VTEC Solenoid Valve
    * not a valid code if car does not have a VTEC engine
    ** not with V-6 engine
    22*- Accord Civic CRV CRX Del Sol Odyssey Prelude
    94-98 92-98 n/a n/a 93-97 98 93-98`
    VTEC Oil Pressure Switch
    defective circuit or unplugged / defective oil pressure switch
    23- Accord Civic CRV CRX Del Sol Odyssey Prelude
    98 * 96-98 n/a n/a 94-97 n/a 92-98
    KS (Knock Sensor)
    * not a valid code if V-6 engine
    30- Accord Civic CRV CRX Del Sol Odyssey Prelude
    90-98 * n/a n/a n/a n/a 95 92-98 *
    Automatic Transmission Signal: "A" / SEAF / SEFA / TMA or TMB
    * not a valid code for 1996
    31- Accord Civic CRV CRX Del Sol Odyssey Prelude
    90-95 n/a n/a n/a n/a 95 92-95
    Automatic Transmission Signal "B"
    41- Accord Civic CRV CRX Del Sol Odyssey Prelude
    90-98 92-98 97-98 n/a 93-97 95-98 90-98
    Primary Oxygen Sensor - Heater
    circuit malfunction
    43- Accord Civic CRV CRX Del Sol Odyssey Prelude
    90-95 92-95 n/a n/a 93-95 95 90-95
    Fuel Supply System
    defective or malfunctioning fuel supply system
    45- Accord Civic CRV CRX Del Sol Odyssey Prelude
    96-98 96-98 97-98 n/a 96-97 96-98 96-98
    System Too Lean or Too Rich
    malfunction in the fuel monitoring systems
    48- Accord Civic CRV CRX Del Sol Odyssey Prelude
    98 92-98 n/a n/a n/a n/a n/a
    LAF Sensor (Lean Air Fuel)
    54- Accord Civic CRV CRX Del Sol Odyssey Prelude
    96 96-98 97-98 n/a 96-97 n/a n/a
    CKF Sensor (Crankshaft Speed Fluctuation)
    58- Accord Civic CRV CRX Del Sol Odyssey Prelude
    98 * n/a n/a n/a n/a n/a n/a
    TDC Sensor 2 (Top Dead Center)
    * with V-6 engine only
    61- Accord Civic CRV CRX Del Sol Odyssey Prelude
    Oxygen Sensor, Heated - Sensor 1 (Primary)
    high voltage, low voltage, or slow response
    63- Accord Civic CRV CRX Del Sol Odyssey Prelude
    Oxygen Sensor, Heated - Sensor 2 (Secondary)
    65- Accord Civic CRV CRX Del Sol Odyssey Prelude
    Oxygen Sensor Heater (Secondary)
    malfunctioning or defective oxygen sensor heater
    67- Accord Civic CRV CRX Del Sol Odyssey Prelude
    Catalyst system Efficiency Below Threshold
    malfunctioning or defective catalyst system
    70- Accord Civic CRV CRX Del Sol Odyssey Prelude
    96-98 96-98 97-98 n/a n/a 96-98 96-98
    malfunction with the automatic transmission controls
    71- Accord Civic CRV CRX Del Sol Odyssey Prelude
    Cylinder 1 Misfire or a Random Misfire
    a condition is present that is creating a cylinder misfire
    72- Accord Civic CRV CRX Del Sol Odyssey Prelude
    Cylinder 2 Misfire or a Random Misfire
    73- Accord Civic CRV CRX Del Sol Odyssey Prelude
    Cylinder 3 Misfire or a Random Misfire
    74- Accord Civic CRV CRX Del Sol Odyssey Prelude
    Cylinder 4 Misfire or a Random Misfire
    75- Accord Civic CRV CRX Del Sol Odyssey Prelude
    Cylinder 5 Misfire or a Random Misfire
    * valid code for V-6 engine only
    76- Accord Civic CRV CRX Del Sol Odyssey Prelude
    Cylinder 6 Misfire or a Random Misfire
    80- Accord Civic CRV CRX Del Sol Odyssey Prelude
    96-98 96-98 n/a n/a n/a 96-98 96-98
    insufficient flow detected
    86- Accord Civic CRV CRX Del Sol Odyssey Prelude
    circuit range / performance problem
    90- Accord Civic CRV CRX Del Sol Odyssey Prelude
    97-98 96-98 n/a n/a n/a 98 97-98
    Evaporative Emission Control System
    leak detected in the fuel tank area
    91- Accord Civic CRV CRX Del Sol Odyssey Prelude
    96-98 96-98 n/a n/a n/a 98 97-98
    Fuel Tank Pressure Sensor
    low input
    92- Accord Civic CRV CRX Del Sol Odyssey Prelude
    96-98 96-98 97-98 n/a 96-97 96-97 96-98
    insufficient purge flow
    85-87 obd0 codes
    LED display Symptom - Possible Cause for 1985 through 1987 Honda Vehicles
    Note: OOOO all 4 lamps on, XXXX all 4 lamps off
    OOOO Engine will not start - Check for disconnected control unit ground connector. Also check for a loose connection at the ECU main relay resistor. Possible faulty ECU.
    OOOO Engine will not start - Check for a short circuit in the combination meter or warning light wire. Also check for a disconnected control unit ground wire. Possible faulty ECU.
    OOOX System does not operate - Faulty ECU
    OOXO System does not operate - Faulty ECU
    OOXX Fuel-fouled spark plugs, engine stalls frequently - Check for a disconnected MAP sensor coupler or an open circuit in the MAP sensor wire. Also faulty MAP sensor.
    OXOO System does not operate - Faulty ECU.
    OXOX Hesitation, fuel-fouled spark plugs or engine stalls frequently - Check for disconnected MAP sensor vacuum hose.
    OXXO High idle speed during warm-up, continued high or hard starting at low temperature - Check for disconnected coolant temperature sensor connector or an open circuit in the coolant temperature sensor wire. Also faulty Coolant Temperature sensor.
    OXXX Poor engine response when opening the throttle rapidly, high idle speed or engine does not rev-up when cold - Check for a disconnected throttle angle sensor connector. Also check for an open circuit in the throttle angle sensor wire. Also faulty throttle angle sensor.
    XOOO Engine dose not rev-up, high idle speed or erratic idling - Check for a short or open in the crank angle sensor wire. Spark plug wires interfering with the crank angle sensor wire. Also faulty crank angle sensor.
    XOOX Same as above (XOOO)
    XOXO High idle speed or erratic idling when very cold - Check for disconnected intake air temperature sensor or an open circuit in the intake air temperature sensor wire. Also faulty Intake Air Temperature sensor.
    XOXX Continued high idle speed - Check for a disconnected idle mixture adjuster sensor coupler or an open circuit in the idle mixture adjuster sensor wire. Also faulty Idle Mixture Adjuster sensor.
    XXOO System does not operate at all - Faulty ECU
    XXOX Poor acceleration at high altitude when cold - Check for a disconnected atmospheric pressure sensor coupler or an open circuit in the atmospheric pressure sensor wire. Also faulty Atmospheric Pressure Sensor.
    XXXO System does not operate at all - Faulty ECU
    XXXX Same as above (XXXO)
    CODE PROBABLE CAUSE for Honda Vehicles 1988 and later.
    0 Faulty ECU (no signal)
    1 Oxygen sensor or circuit.
    2 Faulty ECU
    3 & 5 Manifold Absolute Pressure (MAP) sensor or circuit.
    4 Crank angle sensor or circuit
    6 Coolant temperature sensor or circuit
    7 Throttle angle sensor or circuit.
    8 TDC position/crank angle sensor or circuit.
    9 Crank angle sensor or circuit
    10 Intake air temperature sensor or circuit.
    11 No particular symptom shown or system does not operate - faulty ECU
    12 Exhaust gas recirculation (EGR) failure
    13 Atmospheric pressure sensor circuit.
    14 Electronic air control valve (EACV)
    15 No ignition output signal - possible faulty igniter.
    16 Fuel injector circuit.
    17 Vehicle speed sensor or circuit (VSS)
    19 Lock-up control solenoid valve (automatic transmission)
    20 Electronic load detector - possible open or grounded circuit in ECU wiring.
    21 VTEC spool solenoid valve circuit (Civic & Del-Sol)
    22 VTEC oil pressure switch circuit (Civic & Del-Sol)
    23 Knock sensor (Prelude)
    30 A/T control unit ECM fuel injection signal "A" (Accord & Prelude)
    31 A/T control unit ECM fuel injection signal "B" (Accord & Prelude)
    41 Heated oxygen sensor - heater circuit.
    43 Fuel supply system circuit (except D15Z1 engine)
    45 Fuel system out of range - rich or lean
    48 Heated oxygen sensor circuit (D15Z1 engine)
    50 Mass airflow sensor.
    61 Front oxygen sensor response slow.
    63 Rear oxygen sensor circuit voltage out of range.
    65 Rear oxygen sensor circuit malfunction.
    67 Catalyic converter efficency low.
    70 Automatic Transaxle problem.
    71 through 76 Cylinder misfires
    80 Insufficient EGR flow
    86 Engine coolant temperature sensor circuit.
    92 Evaporative emission purge valve problem
    *Please only use this as a guide* As some are different. This should only be used as a starting point.
    1 person likes this.
  2. pissedoffsol
    Or, if you have a high-tech scan tool.... here's the codes for that.
    P0010 Variable Valve Timing Control (VTC) Oil Control Solenoid Valve Malfunction
    P0011 Variable Valve Timing Control (VTC) System Malfunction
    P0101 Mass Airflow (MAF) Sensor Range/Performance Problem
    P0102 Mass Airflow (MAF) Sensor Circuit Low Voltage
    P0103 Mass Airflow (MAF) Sensor Circuit High Voltage
    P0106 Manifold Absolute Pressure (MAP) Sensor Range/Performance Problem
    P0107 Manifold Absolute Pressure (MAP) Sensor Circuit Low Voltage
    P0108 Manifold Absolute Pressure (MAP) Sensor Circuit High Voltage
    P0111 Intake Air Temperature (IAT) Sensor Circuit Range/Performance Problem
    P0112 Intake Air Temperature (IAT) Sensor Circuit Low Voltage
    P0113 Intake Air Temperature (IAT) Sensor Circuit High Voltage
    P0116 Engine Coolant Temperature (ECT) Sensor Circuit Range/Performance Problem
    P0117 Engine Coolant Temperature (ECT) Sensor Circuit Low Input
    P0118 Engine Coolant Temperature (ECT) Sensor Circuit High Input
    P0122 Throttle Position (TP) Sensor Circuit Low Input
    P0123 Throttle Position (TP) Sensor Circuit High Input
    P0125 Engine Coolant Temperature (ECT) Sensor Slow Response
    P0128 Cooling System Malfunction
    P0131 Primary Heated Oxygen Sensor (Primary HO2S) (Sensor 1) Circuit Low Voltage
    P0132 Primary Heated Oxygen Sensor (Primary HO2S) (Sensor 1) Circuit High Voltage
    P0133 Rear Air/Fuel Ratio (A/F) Sensor (Bank 1, Sensor 1) Circuit Slow Response
    P0134 Air/Fuel Ratio (A/F) Sensor (Sensor 1) No Activity Detected
    P0135 Primary Heated Oxygen Sensor (Primary HO2S) (Sensor 1) Heater Circuit Malfunction
    P0137 Secondary Heated Oxygen Sensor (Secondary HO2S) Circuit Low Voltage
    P0138 Secondary Heated Oxygen Sensor (Secondary HO2S) Circuit High Voltage
    P0139 Secondary Heated Oxygen Sensor (Secondary HO2S) Slow Response
    P0141 Secondary Heated Oxygen Sensor (Secondary HO2S) (Sensor 2) Heater Circuit Malfunction
    P0143 Third Heated Oxygen Sensor (Third HO2S) (Sensor 3) Circuit Low Voltage
    P0144 Third Heated Oxygen Sensor (Third HO2S) (Sensor 3) Circuit High Voltage
    P0145 Third Heated Oxygen Sensor (Third HO2S) (Sensor 3) Circuit Slow Response
    P0147 Third Heated Oxygen Sensor (Third HO2S) (Sensor 3) Heater Circuit Malfunction
    P0153 Front Air/Fuel Ratio (A/F) Sensor (Bank 2, Sensor 1) Circuit Slow Response
    P0154 Front Air/Fuel Ratio (A/F) Sensor (Bank 2, Sensor 1) Heater System Malfunction
    P0155 Front Air/Fuel Ratio (A/F) Sensor (Bank 2, Sensor 1) Heater Circuit Malfunction
    P0157 Front Secondary Heated Oxygen Sensor (Secondary HO2S) (Bank 2, Sensor 2)
    Circuit Low Voltage
    P0158 Front Secondary Heated Oxygen Sensor (Secondary HO2S) (Bank 2, Sensor 2)
    P0159 Front Secondary Heated Oxygen Sensor (Secondary HO2S) (Bank 2, Sensor 2)
    P0161 Front Secondary Heated Oxygen Sensor (Secondary HO2S) (Bank 2, Sensor 2)
    P0171 Fuel System Too Lean
    P0172 Fuel System Too Rich
    P0174 Front Bank (Bank 2) Fuel System Too Lean
    P0175 Front Bank (Bank 2) Fuel System Too Rich
    P0191 Fuel Pressure Sensor Range/Performance Problem
    P0192 Fuel Pressure Sensor Circuit Low Voltage
    P0193 Fuel Pressure Sensor Circuit High Voltage
    P0196 EOT Sensor/Range Performance Problem
    P0197 EOT Sensor Circuit Low Voltage
    P0198 EOT Sensor Circuit High Voltage
    P0222 Throttle Position (TP) Sensor 2 Circuit Low Voltage
    P0223 Throttle Position (TP) Sensor 2 Circuit High Voltage
    P0300 Random Misfire
    P0301 No. 1 Cylinder Misfire
    P0302 No. 2 Cylinder Misfire
    P0303 No. 3 Cylinder Misfire
    P0304 No. 4 Cylinder Misfire
    P0305 No. 5 Cylinder Misfire
    P0306 No. 6 Cylinder Misfire
    P0325 Knock Sensor Circuit Malfunction
    P0335 Crankshaft Position (CKP) Sensor Circuit No Signal
    P0336
    P0339
    Crankshaft Position (CKP) Sensor Circuit Intermittent Interruption
    P0340 Camshaft Position (CMP) Sensor No Signal
    P0341 Camshaft Position (CMP) Sensor A Intermittent Interruption
    P0341 Variable Valve Timing Control (VTC) Phase Gap
    P0344 Camshaft Position (CMP) Sensor Intermittent Interruption
    P0365 Camshaft Position (CMP) Sensor B No Signal
    P0366
    P0369
    Camshaft Position (CMP) Sensor B Intermittent Interruption
    P0385 Crankshaft Position (CKP) Sensor B No Signal
    P0389 Crankshaft Position (CKP) Sensor B Intermittent Interruption
    P0401 Exhaust Gas Recirculation (EGR) Insufficient Flow
    P0404 Exhaust Gas Recirculation (EGR) Control Circuit Range/Performance Problem
    P0406 Exhaust Gas Recirculation (EGR) Valve Position Sensor Circuit High Voltage
    P0410 Air Pump Circuit Malfunction
    P0411 Secondary Air Injection System Incorrect Flow
    P0420 Catalyst System Efficiency Below Threshold
    P0430 Front Bank Catalyst System Efficiency Below Threshold (Bank 2)
    P0441 Evaporative Emission (EVAP) Control System Incorrect Purge Flow
    P0442 Evaporative Emission (EVAP) System Small Leak Detected
    P0443 Evaporative Emission (EVAP) Canister Purge Valve Circuit Malfunction
    P0451 Fuel Tank Pressure (FTP) Sensor Range/Performance Problem
    P0452 Fuel Tank Pressure (FTP) Sensor Circuit Low Voltage
    P0453 Fuel Tank Pressure (FTP) Sensor Circuit High Voltage
    P0456 Evaporative Emission (EVAP) System Very Small Leak Detected
    P0457 Evaporative Emission (EVAP) System Leak Detected Fuel Fill Cap Loose/Off
    P0461 Fuel Gauge Sending Unit Range/Performance Problem
    P0462 Fuel Gauge Sending Unit Circuit Low Voltage
    P0463 Fuel Gauge Sending Unit Circuit High Voltage
    P0496 Evaporative Emission (EVAP) System High Purge Flow
    P0497 Evaporative Emission (EVAP) System Low Purge Flow
    P0498 Evaporative Emission (EVAP) Canister Vent Shut Valve Control Circuit Low Voltage
    P0499 Evaporative Emission (EVAP) Canister Vent Shut Valve Control Circuit High Voltage
    P0500 Vehicle Speed Sensor (VSS) Circuit Malfunction
    P0501 Vehicle Speed Sensor (VSS) Range/Peformance Problem
    P0505 Idle Control System Malfunction
    P0506 Idle Control System RPM Lower Than Expected
    P0507 Idle Control System RPM Higher Than Expected
    P0511 Idle Air Control (IAC) Valve Circuit Malfunction
    P0521 EOP Sensor Range/Performance Problem
    P0522 EOP Sensor Circuit Low Voltage
    P0523 EOP Sensor Circuit High Voltage
    P0560 ECM Back-up Circuit Low Voltage
    P0563 Engine Control Module (ECM)/Powertrain Control Module (PCM) Power Source Circuit
    Unexpected Voltage
    P0600 Multiplex Control System Troubleshooting
    P0603 ECM/PCM Internal Control Module Keep Alive Memory (KAM) Error
    P0606 ECM/PCM Processor Malfunction
    P0661 Intake Manifold Runner Control (IMRC) Valve Position Sensor Circuit Low Voltage
    P0662 Intake Manifold Runner Control (IMRC) Valve Position Sensor Circuit High Voltage
    P0685 ECM/PCM Power Relay Control Circuit Malfunction
    P0700 Automatic Transmission Control System
    P0705 Short in Transmission Range Switch Circuit (Multiple Shift-position Input)
    P0706 Open in Transmission Range Switch Circuit
    P0710
    P0711
    Problem in ATF Temperature Sensor Circuit
    P0712 Short in ATF Temperature Sensor Circuit
    P0713 Open in ATF Temperature Sensor Circuit
    P0715
    P0716
    Problem in Mainshaft Speed Sensor Circuit
    P0717 Problem in Mainshaft Speed Sensor Circuit (No Signal Input)
    P0718 Mainshaft Speed Sensor Intermittent Failure
    P0720 Countershaft Speed Sensor Circuit Malfunction
    P0720
    P0721
    Problem in Countershaft Speed Sensor Circuit
    P0722 Problem in Countershaft Speed Sensor Circuit (No Signal Input)
    P0723 Countershaft Speed Sensor Intermittent Failure
    P0725 Engine Speed Input Circuit Malfunction
    P0730 Problem in Shift Control System
    P0731 Problem in 1st Clutch and 1st Clutch Hydraulic Circuit
    P0732 Problem in 2nd Clutch and 2nd Clutch Hydraulic Circuit
    P0733 Problem in 3rd Clutch and 3rd Clutch Hydraulic Circuit
    P0734 Problem in 4th Clutch and 4th Clutch Hydraulic Clutch
    P0735 Problem in 5th Clutch and 5th Clutch Hydraulic Circuit
    P0740 Problem in Lock-up Control System
    P0741 Torque Converter Clutch Hydraulic Clutch Stuck OFF
    P0743 Problem in Torque Converter Clutch Solenoid Valve Circuit
    P0745 Problem in Hydraulic Control System of A/T Clutch Pressure Control Solenoid Valve A Circuit
    P0746 A/T Clutch Pressure Control Solenoid Valve A Stuck OFF
    P0747 A/T Clutch Pressure Control Solenoid Valve A Stuck ON
    P0748 Problem in A/T Clutch Pressure Control Solenoid Valve A Circuit
    P0750 Problem in Hydraulic Control System of Shift Solenoid Valve A Circuit
    P0751 Shift Solenoid Valve A Stuck OFF
    P0752 Shift Solenoid Valve A Stuck ON
    P0753 Problem in Shift Solenoid Valve A Circuit
    P0756 Shift Solenoid Valve B Stuck OFF
    P0757 Shift Solenoid Valve B Stuck ON
    P0758 Problem in Shift Solenoid Valve B Circuit
    P0761 Shift Solenoid Valve C Stuck OFF
    P0762 Shift Solenoid Valve C Stuck ON
    P0763 Problem in Shift Solenoid Valve C Circuit
    P0771 Shift Solenoid Valve E Stuck OFF
    P0773 Problem in Shift Solenoid Valve E Circuit
    P0775 Problem in the Hydraulic Control System of A/T Clutch Pressure Control Solenoid Valve B
    Circuit
    P0776 A/T Clutch Pressure Control Solenoid Valve B Stuck OFF
    P0777 A/T Clutch Pressure Control Solenoid Valve B Stuck ON
    P0778 Problem in A/T Clutch Pressure Control Solenoid Valve B Circuit
    P0780 Problem in Shift Control System
    P0795 Problem in Hydraulic Control System of A/T Clutch Pressure Control Solenoid Valve C Circuit
    P0796 A/T Clutch Pressure Control Solenoid Valve C Stuck OFF
    P0797 A/T Clutch Pressure Control Solenoid Valve C Stuck ON
    P0798 Problem in A/T Clutch Pressure Control Solenoid Valve C Ciruit
    P0812 Open in Transmission Range Switch ATP RVS Switch Circuit
    P0842 Short in 2nd Clutch Transmission Fluid Pressure Switch Clutch, or 2nd Clutch Transmission
    Fluid Pressure Switch (Clutch) Stuck ON
    P0843 Open in 2nd Clutch Transmission Fluid Pressure Switch Circuit, or 2nd Clutch Transmission
    Fluid Pressure Switch Stuck OFF
    P0845 Problem in 3rd Clutch Pressure Switch Circuit
    P0847 Short in 3rd Clutch Transmission Fluid Pressure Switch Circuit, or 3rd Clutch Transmission
    Fluid Pressure Switch Stuck ON
    P0848 Open in 3rd Clutch Transmission Fluid Pressure Switch Circuit, or 3rd Clutch Transmission
    P0872 Short in 4th Clutch Transmission Fluid Pressure Switch Circuit, or 4th Clutch Transmission
    P0873 Open in 4th Clutch Transmission Fluid Pressure Switch Circuit, or 4th Clutch Transmission
    P0962 Problem in A/T Clutch Pressure Control Solenoid Valve A Circuit
    P0963 Problem in A/T Clutch Pressure Control Solenoid Valve A
    P0966 Problem in A/T Clutch Pressure Control Solenoid Valve B Circuit
    P0967 Problem in A/T Clutch Pressure Control Solenoid Valve B
    P0970 Problem in A/T Clutch Pressure Control Solenoid Valve C Circuit
    P0971 Problem in A/T Clutch Pressure Control Solenoid Valve C
    P0973 Short in Shift Solenoid Valve A Circuit
    P0974 Open in Shift Solenoid Valve A Circuit
    P0976 Short in Shift Solenoid Valve B Circuit
    P0977 Open in Shift Solenoid Valve B Circuit
    P0979 Short in Shift Solenoid Valve C Circuit
    P0980 Open in Shift Solenoid Valve C Circuit
    P0982 Short in Shift Solenoid Valve D Circuit
    P0983 Open in Shift Solenoid Valve D Circuit
    P0985 Short in Shift Solenoid Valve E Circuit
    P0986 Open in Shift Solenoid Valve E Circuit
    P1020 Valve Pause System Stuck Off
    P1021 Valve Pause System Stuck On
    P1025 Valve Pause System Sticking Off
    P1026 Valve Pause System Sticking On
    P1077 Intake Manifold Runner Control (IMRC) System Malfunction (Low rpm)
    P1078 Intake Mainfold Runner Control (IMRC) System Malfunction (High rpm)
    P1106 Barometric Pressure (BARO) Sensor Circuit Range/Performance Problem
    P1107 Barometric Pressure (BARO) Sensor Circuit Low Voltage
    P1108 Barometric Pressure (BARO) Sensor Circuit High Voltage
    P1121 Throttle Position (TP) Sensor Lower Than Expected
    P1122 Throttle Position (TP) Sensor Higher Than Expected
    P1128 Manifold Absolute Pressure (MAP) Sensor Circuit Lower Than Expected
    P1129 Manifold Absolute Pressure (MAP) Sensor Circuit Higher Than Expected
    P1130 Demand for Changing Both Secondary Heated Oxygen Sensor (Secondary HO2S)
    (Sensor 2) and Third Heated Oxygen Sensor (Third HO2S) (Sensor 3)
    P1149 Air/Fuel Ratio (A/F) Sensor (Sensor 1) Range/Performance Problem
    P1149 Air/Fuel Ratio Sensor (Sensor 1) Circuit Lean Range
    P1157 Air/Fuel Ratio (A/F) Sensor (Sensor 1) AFS Line High Voltage
    P1157 Air/Fuel Ratio (A/F) Sensor (Sensor 1) Circuit High Voltage
    P1157 Air/Fuel Ratio (A/F) Sensor (Sensor 1) Range/Performance Problem
    P1158 Air/Fuel Ratio (A/F) Sensor (Sensor 1) AFS- Terminal Low Voltage
    P1159 Air/Fuel Ratio (A/F) Sensor (Sensor 1) AFS+ Terminal Low Voltage
    P1162 Air/Fuel Ratio (A/F) Sensor (Sensor 1) Slow Response
    P1163 Air/Fuel Ratio (A/F) Sensor (Sensor 1) Slow Response
    P1163 Air/Fuel Ratio Sensor (Sensor 1) Slow Response
    P1164 Air/Fuel Ratio (A/F) Sensor (Sensor 1) Range/Performance Problem
    P1164 Air/Fuel Ratio (AF) Sensor (Sensor 1) Circuit Range/Performance
    P1165 Air/Fuel Ratio (A/F) Sensor (Sensor 1) Range/Performance Problem
    P1165 Air/Fuel Ratio Sensor (Sensor 1) Circuit Range/Performance
    P1166 Air/Fuel Ratio (A/F) Sensor (Sensor 1) Heater System Electrical Problem
    P1166 Heated Oxgen Sensor Sensor1 (Primary HO2S) Heater Circuit Malfunction
    P1167 Air/Fuel Ratio (A/F) Sensor (Sensor 1) Heater System Malfunction
    P1167 Heated Oxygen Sensor Sensor1 (Primary LAF HO2S) Heater System Malfunction
    P1168 Air/Fuel Ratio (A/F) Sensor (Sensor 1) LABEL Low Voltage
    P1169 Air/Fuel Ratio (A/F) Sensor (Sensor 1) LABEL High Voltage
    P1182 Fuel Temperature Sensor Circuit Low Voltage
    P1183 Fuel Temperature Sensor Circuit High Voltage
    P1253
    P1259
    VTEC System Malfunction
    P1297 Electric Load Detector (ELD) Circuit Low Voltage
    P1298 Electric Load Detector (ELD) Circuit High Voltage
    P1300 Random Misfire
    P1324 Knock Sensor Power Source Circuit Low Voltage
    P1336 Engine Speed (RPM) Fluctuation Sensor Intermittent Interruption
    P1337 Engine Speed (RPM) Fluctuation Sensor No Signal
    P1355 Front Ignition Coil Power Circuit Malfunction
    P1359 Crankshaft Position (CKP)/Top Dead Center (TDC) Sensor Circuit Malfunction
    P1361 Camshaft Position (CMP) Sensor A (Top Dead Center (TDC) Sensor) Intermittent Interruption
    P1361 Top Dead Center (TDC) Sensor Intermittent Interruption
    P1362 Camshaft Position (CMP) Sensor A (Top Dead Center (TDC) Sensor) No Signal
    P1362 Top Dead Center (TDC) Sensor No Signal
    P1366 Camshaft Position (CMP) Sensor B (Top Dead Center (TDC) Sensor) Intermittent Interruption
    P1366 Top Dead Center (TDC) Sensor 2 Intermittent Interruption
    P1367 Camshaft Position (CMP) Sensor B (Top Dead Center (TDC) Sensor) No Signal
    P1367 Top Dear Center (TDC) Sensor 2 No Signal
    P1381 Cylinder Position (CYP) Sensor Intermittent Interruption
    P1382 Cylinder Position (CYP) Sensor No Signal
    P1410 Air Pump Malfunction
    P1415 Air Pump Electric Current Sensor Circuit Low Voltage
    P1416 Air Pump Electric Current Sensor Circuit High Voltage
    P1420 Nox Adsorptive Catalyst System Efficiency Below Threshold
    P1438 Motor Drive Module (MDM) Overheating Signal Circuit
    P1439 Motor Drive Module (MDM) Short Circuit Sensor Problem
    P1440 IMA System Problem
    P1445 Bypass Control Problem
    P1448
    P1449
    Battery Module Overheating
    P1449 Battery Cell Overheating
    P1449 Battery Module Individual Voltage Input Deviation
    P1449 Battery Module Deterioration
    P1449 Battery Module Deviation
    P1454 Fuel Tank Pressure (FTP) Sensor Range/Performance Problem
    P1456 Evaporative Emissions (EVAP) Control System Leakage (Fuel Tank System)
    P1457 Evaporative Emissions (EVAP) Control System Leakage (EVAP Canister System)
    P1459 Evaporative Emission (EVAP) Purge Flow Switch Malfunction
    P1491 Exhaust Gas Recirculation (EGR) Valve Insufficient Lift
    P1486 Cooling System Malfunction
    P1498 Exhaust Gas Recirculation (EGR) Valve Position Sensor Circuit High Voltage
    P1505 Positive Crankcase Ventilation (PCV) Air Leakage
    P1508
    P1519
    Idle Air Control Valve (IACV) Circuit Malfunction
    P1509 Idle Air Control Valve (IACV) Circuit Failure
    P1522 Brake Booster Pressure Sensor Circuit Low Voltage
    P1523 Brake Booster Pressure Sensor Circuit High Voltage
    P1524 Brake Booster Pressure Sensor Range/Performance Problem
    P1541 Climate Control Unit Signal Circuit Low Voltage
    P1542 Climate Control Unit Signal Circuit High Voltage
    P1565 Motor Commutation Signal Problem
    P1568 Battery Module Individual Voltage Input Problem
    P1568 Battery Module Temperature Signal Circuit Problem
    P1568 Battery Cell Temperature Signal Circuit Problem
    P1572 Motor Drive Module (MDM) Temperature Signal Circuit Low Input
    P1572 Motor Drive Module (MDM) Temperature Signal Circuit High Input
    P1576 Motor Drive Module (MDM) Voltge Signal Circuit Low Input
    P1577 High Voltage Detection Signal Circuit Problem
    P1580 Battery Current Circuit Problem
    P1581 Motor Power Inverter (MPI) Module Current Signal Circuit Low Input
    P1581 Motor Power Inverter (MPI) Module Current Signal Circuit High Input
    P1581 Motor Power Inverter (MPI) Module Current Signal Circuit Problem
    P1582 Motor Current U Phase Signal Circuit Low Input
    P1582 Motor Current U Phase Signal Circuit High Input
    P1583 Motor Current V Phase Signal Circuit Low Input
    P1583 Motor Current V Phase Signal Circuit High Input
    P1584 Motor Current W Phase Signal Circuit Low Input
    P1584 Motor Current W Phase Signal Circuit High Input
    P1585 Motor Current Signal Circuit Problem
    P1586 Motor Power Inverter (MPI) Module Current Signal/Battery Current Signal Circuit Problem
    P1607 Engine Control Module (ECM)/Powertrain Control Module (PCM) Internal Circuit Malfunction
    P1630 Transmission Control Module
    P1635 Battery Condition Monitor (BCM) Module Proble
    P1639 MOTB Signal Circuit Malfunction
    P1640 ACTTRQ Motor Torque Signal Circuit Low Input
    P1641 ACTTRQ Motor Torque Signal Circuit High Input
    P1642 QBATT Battery Signal Circuit Low Input
    P1643 QBATT Battery Signal Circuit High Input
    P1644 MOTFSA Signal Malfunction
    P1645 MOTFSB Signal Malfunction
    P1646 MOTSTB Signal Malfunction
    P1647 Power Command Signal Circuit Low Input
    P1647 Power Command Signal Circuit High Input
    P1647 Engine Torque Signal Circuit Low Input
    P1647 Engine Torque Signal Circuit High Input
    P1647 Mode Signal Circuit 1 Low Input
    P1647 Mode Signal Circuit 1 High Input
    P1647 Mode Signal Circuit 2 Problem
    P1647 Engine Speed Signal Circuit Problem
    P1648 Battery Condition Monitor (BCM) Module Communication Signal Circuit Problem
    P1648 Motor Control Module (MCM) Communication Signal Circuit Problem
    P1655 CVT-FI TMA/TMB Signal Line Failure
    P1656 Problem in PCM-toVTM-4 Control Unit Communications Circuit
    P1660 A/T-FI Data Line Failure/TCM - ECM Halt
    P1676
    P1678
    FPTDR Signal Line Failure
    P1679 RSCD Signal Circuit Malfunction
    P1681 A/T FI Signal A Cicuit Low Voltage
    P1682 A/T FI Signal A Circuit High Voltage
    P1683 Throttle Valve Default Position Spring Performance Problem
    P1684 Throttle Valve Return Spring Performance Problem
    P1686 A/T FI Signal B Circuit Low Voltage
    P1687 A/T FI Signal B Circuit High Voltage
    P1705 Short in Transmission Range Switch Circuit (More than one range position is on at the
    same time)
    P1706 Open in Transmission Range Switch Circuit
    P1709 Problem Transmission Gear Selection Switch Circuit
    P1730 Problem in Shift Control System:
    Shift Solenoid Valve A and D Stuck OFF
    Shift Valves A, B, and D Stuck
    P1731 Problem in Shift Control System:
    Shift Solenoid Valve E Stuck ON
    Shift Valve E Stuck
    P1732 Problem in Shift Control System:
    Shift Solenoid Valve B and C Stuck ON
    Shift Valves B and C Stuck
    P1733 Problem in Shift Control System:
    Shift Solenoid Valve D Stuck ON
    Shift Valve D Stuck
    P1734 Problem in Shift Control System:
    Shift Solenoid Valves B and C Stuck ON
    P1738 Problem in 2nd Clutch Pressure Switch Circuit
    P1739 Problem in 3rd Clutch Pressure Switch Circuit
    P1740 Problem in 4th Clutch Pressure Switch Circuit
    P1750 Mechanical Problem in Hydraulic Control System of A/T Clutch Pressure Control Solenoid
    Valve Assemblies A and B, or Problem in the Hydraulic Control System
    P1751 Mechanical Problem in Hydraulic Control System of Shift Solenoid Valve B and A/T Clutch
    Pressure Control Solenoid Valves A and B, or Problem in the Hydraulic Control System
    P1753 Problem in Torque Converter Clutch Solenoid Valve Circuit
    P1751
    P1768
    Problem in Torque Converter Clutch Solenoid Valve B Circuit
    P1773 Problem in A/T Clutch Pressure Control Solenoid Valve B Circuit
    P1790 Throttle Position (TP) Sensor Circuit Malfunction
    P1791 Vehicle Speed Sensor (VSS) Range/Performance Problem
    P1792 Problem in Engine Coolant Temperature (ECT) Sensor Circuit
    P1793 Manifold Absolute Pressure Sensor Circuit
    P1870 Problem in CVT Speed Change Control Valve Assembly Circuit
    P1873 Problem in CVT Pulley Pressure Control Valve Assembly Circuit
    P1879 Problem in CVT Start Clutch Pressure Control Valve Assembly Circuit
    P1882 Problem in Inhibitor Solenoid Circuit
    P1884 Secondary Gear Speed Sensor 2 Circuit Malfunction
    P1885 CVT Drive Pulley Speed Sensor Circuit
    P1886 CVT Driven Pulley Speed Sensor Circuit
    P1888 CVT Speed Sensor
    P1889 Problem in CVT Speed Sensor 2 Circuit
    P1890 Shift Control System
    P1891 Problem in Start Clutch System
    P1894 CVT Speed Change Control Valve Circuit
    P1895 CVT Pulley Pressure Control Valve Circuit
    P2101 Throttle Actuator System Malfunction
    P2108 Throttle Actuator Control Module Problem
    P2118 Throttle Actuator Current Range/Performance Problem
    P2122 Accelerator Pedal Position (APP) Sensor 1 (Throttle Position Sensor D) Circuit Low Voltage
    P2123 Accelerator Pedal Position (APP) Sensor 1 (Throttle Position Sensor D) Circuit High Voltage
    P2127 Accelerator Pedal Position (APP) Sensor 2 (Throttle Position Sensor E) Circuit Low Voltage
    P2128 Accelerator Pedal Position (APP) Sensor 2 (Throttle Position Sensor E) Circuit High Voltage
    P2135 Throttle Position (TP) Sensor 1/2 Incorrect Voltage Correlation
    P2138 Accelerator Pedal Position (APP) Sensor 1/2 (Throttle Position Sensor D/E) Incorrect Voltage
    Correlation
    P2176 Throttle Actuator Control System Idle Position Not Learned
    P2195 Air/Fuel Ratio (A/F) Sensor (Sensor 1) Signal Stuck Lean
    P2197 Front Air/Fuel Ratio (A/F) Sensor (Bank 2, Sensor 1) Signal Stuck Lean
    P2227 Barometric Pressure (BARO) Sensor Circuit Range/Performance Problem
    P2228 Barometric Pressure (BARO) Sensor Circuit Low Voltage
    P2229 Barometric Pressure (BARO) Sensor Circuit High Voltage
    P2237 Rear Air/Fuel Ratio (A/F) Sensor (Bank 1, Sensor 1) IP Line High Voltage
    P2238 Air/Fuel Ratio (A/F) Sensor (Sensor 1) AFS+ Line Low Voltage
    P2238 Rear Air/Fuel Ratio (A/F) Sensor (Bank 1, Sensor 1) IP Line Low Voltage
    P2240 Front Air/Fuel Ratio (A/F) Sensor (Bank 2, Sensor 1) IP Line High Voltage
    P2241 Front Air/Fuel Ratio (A/F) Sensor (Bank 2, Sensor 1) IP Line Low Voltage
    P2243 Rear Air/Fuel Ratio (A/F) Sensor (Bank 1, Sensor 1) VCENT Line High Voltage
    P2245 Rear Air/Fuel Ratio (A/F) Sensor (Bank 1, Sensor 1) VCENT Line Low Voltage
    P2247 Front Air/Fuel Ratio (A/F) Sensor (Bank 2, Sensor 1) VCENT Line High Voltage
    P2249 Front Air/Fuel Ratio (A/F) Sensor (Bank 2, Sensor 1) VCENT Line Low Voltage
    P2251 Rear Air/Fuel Ratio (A/F) Sensor (Bank 1, Sensor 1) VS Line High Voltage
    P2252 Air/Fuel Ratio (A/F) Sensor (Sensor 1) AFS- Line Low Voltage
    P2254 Front Air/Fuel Ratio (A/F) Sensor (Bank 2, Sensor 1) VS Line High Voltage
    P2255 Front Air/Fuel Ratio (A/F) Sensor (Bank 2, Sensor 1) VS Line Low Voltage
    P2279 Intake Air System Leak
    P2413 Exhaust Gas Recirculation (EGR) System Range/Performance Problem
    P2422 Evaporative Emission (EVAP) System Vent Shut Valve Close Malfunction
    P2552 Throttle Actuator Control Module Relay Malfunction
    P2627 Rear Air/Fuel Ratio (A/F) Sensor (Bank 1, Sensor 1) LABEL Circuit Low Voltage
    P2628 Rear Air/Fuel Ratio (A/F) Sensor (Bank 1, Sensor 1) LABEL Circuit High Voltage
    P2630 Front Air/Fuel Ratio (A/F) Sensor (Bank 2, Sensor 1) LABEL Circuit Low Voltage
    P2631 Front Air/Fuel Ratio (A/F) Sensor (Bank 2, Sensor 1) LABEL Circuit High Voltage
    P2646 VTEC Oil Pressure Switch Circuit Low Voltage
    P2647 VTEC Oil Pressure Switch Circuit High Voltage
    P2648 VTEC Solenoid Valve Circuit Low Voltage
    P2649 VTEC Solenoid Valve Circuit High Voltage
    P2769 Short in Torque Converter Clutch Solenoid Valve Circuit
    P2770 Open in Torque Converter Clutch Solenoid Valve Circuit
    P2A00 Air/Fuel Ratio (A/F) Sensor (Sensor 1) Range/Performance Problem
    P2A03 Front A/F Sensor Circuit (Bank 2, Sensor 1) Circuit Range/Performance Problem
    U0073 FCAN Malfunction (Bus-off)
    U0107 Lost Communication With Throttle Actuator Control Module
    U0121 FCAN Malfunction (TCS-PCM)
    U0155 FCAN Malfunction (Gauge Control Module-ECM/PCM)
    2 people like this.
