88 To 91 Si Hubs
88civicHBz6
i'm doing an engine swap on my 88 civic hb base model and need some hubs that will take a 26 spline axel. i would like the whole SI hub including brakes if someone has a set. Let me know thanks.
put 90-93 integra spindles on there. they have bigger brakes and u will be happier with the performance and look. thats what i have and i did the exact same thing ur doin. but integra brakes r better .
u dont need to change ur hubs..onyl only have to do so if you are a 88 crx hf..in which you are not..so dont bother changeing em unbless u want to upgrade to integ...
if he has a 88 base model. TRUST ME he has to change his hubs or spindles. the axles have different splines. they wont work right. i have went through it my self!!!!! i have a 88 std and it didnt work. i know.....!!!!!!
