its not the fuel pump. new pump,filter is flowing fine. new wires,cap,rotor,plugs. changed egr. About to swap in different injectors. washed it yesterday and dizzy took a crap. its arcing on the coil just not on on the iwres to the plugs.
alright. i got it to run. It took awhile to get it started in the morning. but once it fired up it ran like a champ......until it got warm. then it ran like ass with the same bad stutter.
On my way back from the junker it died. Just died. Check engine light is one but no codes. AND the uel pump is not cutting on. Could it be a relay?
ok which one? i checked my main realy and its fine. The other day it blew the Fuel pump fuse. Fixed that and put some seafoam in it, now it runs shittier I'm changing the iacv tomm. i'm running out of ideas
