I've got a few questions:
1) I did a swap and had a pro shop wire the swap, now my battery warning light stays on. The shop and I have checked everything we can think of that would cause this. The system checks ok. There are no issues except the light. Any suggestions?
2) Back-up lights inop. I checked bulbs, fuses, and obvious wiring issues (cut, breaks, etc.)
3) Irratic Idle. The car idles at 4-5k. Any suggestions on slowing this down? I used the factory throttle cable from the d15 that was in the car. Will changing this help?
4) What donor car do I get disc brakes from for the rear? 93 Integra?
Thank you in advance for any suggestions and help.
