89 civic hatch with a d16a8 dohc non vtec
Discussion in 'Civic and CRX - EF' started by Jerame Puffenbarger, Oct 8, 2016.
  1. Jerame Puffenbarger
    Jerame Puffenbarger New Member
    I have a 89 hatchback with a d16a8. It is not starting. I have put a new battery in and a new distributor. But it is still not starting. What could be the problem. I was told it could be the ecu. But what ecu do i need.
  2. dilbeckskate
    dilbeckskate infamous
    Kennesaw Ga
    Theres a laundry list of stuff it could be and you posted a very vauge thread... you need air , fuel , spark , and to be in time , which one are you lacking ? Is it turning over ? Does it spark ? Is fuel getting in the cylinders ? Main relay good ? Thermostat and trans ground good ?
  3. dilbeckskate
    Kennesaw Ga
    On obd0 ecu if red light stays constant its bad if not its more than likely good
  4. Jerame Puffenbarger
    It cranks. But no spark. Its getting fuel
  5. jlicrx
    jlicrx Senior Member
    Colorado Springs
    was it running and just quit or what? the correct ECU is PM7 - you said you replaced the distributor - did you get the spark plug wires in the correct locations on the distributor? no. 1 is at top, no. 3 is at front toward radiator, no. 4 is at bottom and no. 2 is at rear toward firewall
  6. Jerame Puffenbarger
    I took it to a car meet then back home. Then went to take my brother home and it would not start.
  7. jlicrx
    Colorado Springs
    any codes showing on the ECU?
