89 Civic LX Tires?
Discussion in 'Civic and CRX - EF' started by TT01Fanatic, Dec 1, 2008.
  1. TT01Fanatic
    TT01Fanatic I
    Bay Area
    Hey guys, I'm getting new wheels and tires for my car, and the ones that are stock (175/70 R 13) are the puniest things I've ever seen... So I wanted to know what is the maximum tire and wheel width I can get without causing any damage or wear to my wheel wells? Thanks!
  2. GlassHeadlights
    Calgary, AB
    I'd go for 15" in diameter wheels. Any bigger than 15" and it looks bad (looks like a hotwheel car) and it screws up your spedometer. The normal width is 5-6 inches, could probably go 7".
  3. GlassHeadlights
    Calgary, AB
    This is pretty sick:
  4. TT01Fanatic
    TT01Fanatic I
    Bay Area
    ok cool, thanks, I'll look into it :)
  5. Fernpatch
    Fernpatch Member
    Bellingham,WA
    I used to have 205/45/16 tires on a set of 16x7.5 wheels on my 91 si hatch. They were ok in the front but the rears rubbed like a bitch. I would stay away from anything bigger than 15x6.5. There are plenty of good wheels in the 15x6 or 15x6.5 range. Also lots of good tires around a 195/50/15 which should fit great. That was what I went with on my old hatch after I got smart and ditched the heavy ass 16's it had.
  6. GlassHeadlights
    Calgary, AB
    Exactly what you want to hear TT01Fanatic, what he said is absolutely correct.:)
  7. mikey bottles
    mikey bottles Prof. Bottles
    S. Jersey
    im currently running 205/50R15's on a 6.5" wheel, lowered about 2 inch, and have no rubbing issues so you can always consider that as an option too. keep in mind its much easier to find 195/50R15's in stock at tire shops than it is 205/50R15's, around here it is anyway... i work at a shop and have the benefit of adjusting the inventory to keep a spare set in stock for myself incase anything happens to mine.
  8. TT01Fanatic
    TT01Fanatic I
    Bay Area
    I'll take any size that's bigger than the 13 inch nubs I've got on the car right now. 6 inch is *checks a ruler* sounding good to me. I make 6 inch my limit on width, but what if I went with a longer diameter wheel with a lower profile tire to compensate? The stock wheel are 13 inches, and I want to try to bump it up a bit, just an inch is fine, maybe two?
    Tell me what you think!
  9. GlassHeadlights
    Calgary, AB
    Your car didn't come stock with 15"s, it came with 13"s.
    If you already have 15"s I'd stay there.
  10. TT01Fanatic
    TT01Fanatic I
    Bay Area
    oh sorry, I meant 13's yeah. 15 inches would be fine, and I take it they would run okay with lower profile tires?
  11. efhondakid
    Akron-Canton, Ohio
    I have 15x6.5s with 205/50r15s on my EF dropped about 3.5in I had to roll the lips because it was rubbing, but after that I havent had any problems. You could run 15s with a 2inch drop with no problems at all.
  12. TT01Fanatic
    TT01Fanatic I
    Bay Area
    Hey, what are the specs on those wheels and tires?
  13. GlassHeadlights
    Calgary, AB
    I have no idea, just found a pic.
  14. TT01Fanatic
    TT01Fanatic I
    Bay Area
  15. mikey bottles
    S. Jersey
    wheels are rota j mags.. probably 15X6.5 or 15x7
