89 civic problems HELP!
Discussion in 'HYBRID -> ED-EF / DA' started by 89civicLS, May 5, 2009.
  1. 89civicLS
    89civicLS New Member
    MN
    I bought a 89 civic with a 90 ls swap
    cant figure out whats wrong with it
    :confused:
    It backfires and runs like ass. wont rev past 3000 er so
    almost like the ecu is in limp mode but i tried a new ecu any suggestions?
    also changed spark plugs and wires cap and coil ive checked the timing and it seems okay
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    what codes is the ecu flashing
  3. 89civicLS
    MN
  4. 89civicLS
    MN
    im almost to the point where im gunna rip it all out and re do everything
  5. AHHVTEC
    Alabama
    fix those codes and it should be fine
  6. 89civicLS
    MN
    Crankshaft Position Sensor
    Top Dead Center
    CYP Sensor
    the car ran fine when i got it then after a week all three sensor just went out
    it seems like a bigger prob to me
  7. AHHVTEC
    Alabama
    well if it was me i would try a new distributor. it has things in it that can go out and put it in limp mode
  8. 89civicLS
    MN
    alright thats what i was thinking too
    maybe ill try a crank sensor too i did some reading and it said that would make it rev bounce and limp mode
    also cleaning the iac could be clogged and the 02 sensor
  9. 89civicLS
    MN
    any other people wanna help
    got the timing perfect today car starts runs like ass
    also put the new o2 in
  10. thirteen_20
    thirteen_20 EF Tuner
    Anadarko, OK
    all of these are integrated onto the distributor. the entire casing has te be replaced in order to change the sensors. if you change the dizzy to a known-good one, it will probably fix your problem...
