I just got a new tps sensor and harness. The older harness had the wires cut down so bare a had no choice in getting a new tps harness. I just need to know which wires go where. Color of the factory engine harness red/green, yellow/white, green. Colors of the tps harness. Green/white, Red/black, yellow/white. Thanks in advance if anyone can help.
We need to know what year the car is and exact model before the swap and the year of the engine put in to find the exact answer for you.
well if anyone can tell me at least which on is postive and negative on the factory harness iam sure iam can mix and match until the meter gets a proper reading. Someone has to know the answer to this.
Red/Blu goes --> Red/Blk (I know for sure) Yel/Wht --> Yel/Wht (this one should have been obvious...) Grn --> Grn/Wht (Just singled it out...)
