M mighymouse33 New Member Jan 22, 2008 #1 Any body know if you can switch out the corner lights from an 89 to a 91 CRX...maybe even with slight fixins???
AHHVTEC Well-Known Member VIP Jan 22, 2008 #2 i think you have to swap out the little clips to make it work
D15Beater HNFTuning Jan 22, 2008 #3 ahhvtec said: i think you have to swap out the little clips to make it work Click to expand... true...youll need to swap out the headlight brackets....
