89 Crx B16 Turbo help
Quik E
I picked up a project and have some bugs to work out, besides all the cosmetic stuff, the car starts fine, idles ok, but when i try to get into it at 4000rpm it bogs and i get CEL. Now if i ease into it i runs a little better but still cuts all power @ 4000rpm and i get CEL. It will not even build any boost before it cuts out, at least thats is what the boost guage is saying.
What I know:
car is running p28 w/ s100 basemap ( i dont know how to tune, could use some tips )
450 injectors
stock pump ( i have walbro to install, also could use some tips here )
In-line or in-tank pump? I would install the pump, then take the car to get dyno-tuned. But lets start with the obvious... what CEL is it spitting? Also, since you don't even hit boost, the stock map sensor is not stressing. I would also do an oil change and listen for a knock. Irrelevant, but its a turbo honda that doesn't run right... and people are retarded.
