89 crx d16z6 swap no spark HELP!!!HELP!!!
Discussion in 'Civic and CRX - EF' started by davkupiec, Oct 22, 2009.
  1. davkupiec
    davkupiec New Member
    hi im new to the site and new to the car also lol just bought it its a 89 crx hf with a d16z6 motor swap i have a p28 ecu with a jumper harness. Also i have a obdo stock wire harness with a obd1 distributer. I have read a ton of stuff about the wiring for this but i just cant get the car to start. I hear the main really work under my feet and also hear the fuel pump kick on. Also i am getting power to the distributer.I have checked all the grounds and they are good to but is there just a ground wire for the distributer? If any one has any idea on why i just might not be getting spark i would greatly appricate it starting to go crazy!! And im not all that great with the whole wiring thing either but do know how to do it if someone just tells me how. Thanks again
  2. SwapShopRacing
    SwapShopRacing Member
    650n Barranca ave #a Covina, Ca 91723 (626) 261-4
    Have you tested the distributor? If so I would start by going over the dist. wiring. Are you using the HF harness?
  3. davkupiec
    i have tried two diff distributers the one that came with the car and then i got another on from a junk yard that they had told me that it worked but who know but all i really know by testing it is that i am getting power to bothe the neg and pos on the coil aslo i know that its has brand new wires and cap on it is there another way to actually test the distributer
  4. SwapShopRacing
    Yeah you can test the igniter they tend to go out a lot, but I would think that one out of two should be good. Are you getting any cel's? Have you gone over the distrib wiring from the OBD1 conversion?
  5. davkupiec
    cels? sorry like i said im not to smark with the wiring thing and ya i went over the wiring all the colors match up besides the to white wires the one big on and the one small one i put the smaller white wire to the obd1 distributer and the bigger one to the all yellow with green stripe wire but other then that they all matched up to the old wire harness!!! but still nothing
  6. c-rex-beat
    c-rex-beat yeah, it's a vtec.
    tyler, TX
    with the dizzy, did you make a jumper harness or buy one? There is usually 2 white wires that need to be switched around. I would start with that first.
  7. davkupiec
    i had just bought the car and yes there is a jumper harness on it and i tried switching the two white wires and still nothing at all
  8. davkupiec
    also i person that i had bought it off of he said that it ran for like 10 miles then shut off but i dont know if that was true or not thats just what he said!!!
  9. Jeef
    Jeef NO MA'AM Moderator VIP
    Please post these questions about 88-91 crx's in the ef forum. You posted this in the ew forum. I moved this for you to the proper forum.
  10. c-rex-beat
    tyler, TX
    is your check engine light on?
  11. GlassHeadlights
    Calgary, AB
    Possible bad ECU but not likely. I would get a Helms or Haynes manual so you can test the different dizzy parts and know what you're looking for. I've had a coil and an igniter go out on the same dizzy. I've also just had a really bad cap and rotor combo and the car wouldn't run.
  12. davkupiec
    yes the check engine light is on but dosent it usally stay on untill the car can run? and i just really think that im going to but a new dizzy off ebay they are going for 75 dollars and then if that dosent work then i deff know that its something else but if any one has a better idea then let me know thanks for the help guys i will let u know what happins
  13. jlicrx
    jlicrx Senior Member
    Colorado Springs
    when you turn the ignition 'on', the Check Engine Light should come on for 2 seconds (fuel pump primes) and then the light should go off
  14. davkupiec
    ok then yes the check engine light stays on then
  15. munchies91crx
    munchies91crx New Member
    if the check engine light stays on its your fuel pump.
  16. davkupiec
    but i would that cause me to not get spark when im turing the car over alo i disconected the return fuel hose off the fuel rail and a ton of gas came out
  17. SwapShopRacing
    If it's OBD1 the Jumper Harness you are using should be wired up to jump your CEL (Check Engine Light) and read the code from your dash. Or for OBD-0 the LED on you ECU will blink out the code. Anyway, you count the blinks, fast blink = 1 long blink = 10. You can find the trouble codes on the following page: Honda ECU Trouble Codes
    This should help you to figure out what is going on.
  18. RoughKnight
    RoughKnight Christmas Car
    Ottawa, Ont
    Identify/Fix the cels, then post back.
  19. iluvhonda
    iluvhonda New Member
    check crank sensor also ecu might be bad check voltage from the pins that send signal from ecu to distributor also does the distrubutor have internal or external coil? if coil is external and u did not replace it it might be the issue
