89 CRX HF SWAP
Discussion in 'HYBRID -> ED-EF / DA' started by SPPIII89HF, Jul 5, 2005.
  1. SPPIII89HF
    SPPIII89HF Junior Member
    Arizona
    Heres the deal, I have an 89 CRX HF. prefect shape. I want more power and willing to scarifice some MPG for the power. I have been researching and talking to a few tuners that said the easiest and cheapest swap would be the D16A6 and keep the HF tranny for the better gas mileage. I dont plan on racing or anything, just when I feel like slammin on the gas, I wanna go somewhere unlike the car' current status when the AC is on (I live in the dang AZ Desert) :angry: to downshift to 3rd from 5th to go anywhere.
    Help me out guys. Budget is tight, but will spend enough to get the job done. :nod:
  2. ryan89crx
    ryan89crx Senior Member
    Washington State
    when i swapped to my a6 motor/tranny combo my mpg actually went up. i was getting like 30mpg with the HF, but with the SI motor and tranny, i get around 35mpg. but the a6 motor with the HF tranny would definately keep your mpg up, and also net you about a 50hp gain.
    the a6 is a direct drop-in, no wiring changes at all. just make sure you order the clutch for what year your tranny is, and use your current flywheel
  3. SPPIII89HF
    Arizona
    My CRX HF right now gets 47 mpg with no tweeking or anything. Reason to keep the mpg high, is I drive 30 miles to work one way. 35 actually isnt a bad number either. :blink:
    Would the D16A6 Swap be pull out and swap and plug back into everything swap? Meaning a carelessly easy swap.
  4. ripperbone
    ripperbone angry bear
    Oklahoma
    hf trannys suck ass (no power). get a si tranny
  5. SPPIII89HF
    Arizona
    Power? tranny has nothing to do with power. Tranny distributes the power by the engine. The larger gear ratios will do exact what I need. MPG as well as have more power behind the tranny with the D16A6.
  6. ripperbone
    Oklahoma
    so keep your hf tranny and still be slow.
    you could even put a d16z6 w/ your hf tranny in your car and you'll still be slow :fuckyou3:
    you can have all the power in the world in your motor but if your tanny cant support it then what good is it. understand that you want excellent mpg but if your looking for more power than what you got then you have to go with a different tranny
  7. SPPIII89HF
    Arizona
    :feedback: what do think would be a reasonable price for a D16A6 motor and tranny. Where is a good place to get these item close to Arizona.
  8. ripperbone
    Oklahoma
    out in colorado you can pick up a motor and tranny for around 200 or less.
    try some of the junkyards where your at first see what they charge for the setup.
    here is another idea for you also
    http://www.hondaswap.com/forums/index.php?showtopic=29791
  9. ryan89crx
    Washington State
    yes it would. everything plugs right in. the only difference is that the HF has an egr valve, the a6 doesnt. you just let that plug hang, dont worry, you wont throw a CEL. even if you decided to use the SI tranny, you could still use your HF axles, but i wouldnt trust them for racing or anything, but just DD they should be fine
  10. jlicrx
    jlicrx Senior Member
    Colorado Springs
    make sure you use the HF engine harness on the A6 engine (otherwise it won't run) - the A6, if it is 89-91 (not 88) model will have a fast idle control valve on the back of the intake manifold on the driver's side end - the HF harness will not have a plug for it - don't worry about it, just plug vacuum ports and leave it not connected - it only works to increase idle at very low ambient air temperature, below -10C (14F)
  11. SPPIII89HF
    Arizona
    :D Sounds like this swap wouldn't be a bad job to do. <_< Is there any things that I should watch out for doing the swap? Any special tools.
    :wall: I found that on another forum, the tuner left the HF Flywheel... there is probably a difference between the two... weight and size. Which is going to be better for gas mileage while still making the car more fun to drive with the D16A6 in it.
  12. ryan89crx
    Washington State
    not true, i am using the HF harness on my a6, idles fine at 750rpms. never thrown a CEL, never had any issues whatsoever. like i said before, the only thing it that the HF has an EGR, the a6 doesnt. let that plug just hang disconnected, it wont affect anything because the pm6 doesnt even recognize it. you will not get a CEL.
    People also say to use the a6 map sensor/vacuum box because it has 2 less vacuum lines than the a6, you dont have to. I am still running my HF map sensor/box with my a6 but have 2 lines blocked off because they are not necessary. one is for the EGR, the other i cant recall. just look in the SI repair manual, the vacuum lines have #s on them, it will tell you which ones the a6 requires and where to put them. Connect where necessary, block the others off
  13. ryan89crx
    Washington State
    that doesnt work unless you want holes in the top of your pistons. the HF has only 2 valve reliefs per piston, so putting a 16 valve head is going to cause some interference. people have tried it on d-series.org, and it only lasted long enough for the valves to beat the shit out of the pistons. http://www.hondaswap.com/forums/index.php?showtopic=50912
  14. jlicrx
    Colorado Springs
    what is not true about what I said? i don't appreciate some smart ass "thinks-he-knows-it-all" telling me i am wrong and then proceed to say the exact same thing
  15. ryan89crx
    Washington State
    whoops, i misread, i thought you said the other way around...to use the a6 instead of the hf. my bad, take it easy killer, no need to get upset
  16. SPPIII89HF
    Arizona
    Might not have to wreck my rex. Look what I found on ebay. Ebay 91 CRX HF Stripped
    :worthy: Anyone located nearby that can check it for me?
  17. drpenguin
    drpenguin Senior Member
    Salem, Or
    Ah.....I miss my HF motor......wait no I dont!!!!!!
  18. mkiiisuprabeef
    mkiiisuprabeef Junior Member
    JDM 3 Stage VTEC-E d15b is the answer. I was seriously considering this motor while i was delivering pizza. Its a single cam motor that under 2500 RPMs Gos into a lean burning/12 valve mode and brings in killer gas mileage (comparable to a Civic VX) after that it just acts like a normal vtec motor, delivering 130 horse power at 7200 RPM, to top it off, its cheap as hell. This seems like the perfect solution for you, I would look into it.
  19. SPPIII89HF
    Arizona
    Has anyone done this swap?
    I currently put the CRX on hold for while searching for a better engine mod. Honestly, the car isnt worth much so spend more than the cars worth is not realistic. JDM 3 Stage VTEC-E d15b does sound like a good idea.
    Any guides for such a swap?
  20. SPPIII89HF
    Arizona
    I just came accross another interesting factor... AWD CRX! :worthy: Curious how the heck you would going about doing that. Pretty cool tho.
    CRX AWD GSR TURBO - Used for Drifting
    Its is just for thought. This Probably Costs a Fortune to do.
