89 crx no spark!! help!!
davkupiec
hi im new to the site and new to the car also lol just bought it its a 89 crx hf with a d16z6 motor swap i have a p28 ecu with a jumper harness. Also i have a obdo stock wire harness with a obd1 distributer. I have read a ton of stuff about the wiring for this but i just cant get the car to start. I hear the main really work under my feet and also hear the fuel pump kick on. Also i am getting power to the distributer.I have checked all the grounds and they are good to but is there just a ground wire for the distributer? If any one has any idea on why i just might not be getting spark i would greatly appricate it starting to go crazy!! And im not all that great with the whole wiring thing either but do know how to do it if someone just tells me how. Thanks again
well did you check the coil in the dist. for ground, and power? If the coil has ground, and power, and no spark is being made. ( THE COIL WILL BE BAD). Did you check the ecu codes? what have you done so we can help you with your problem?
