89 crx si B18 swapp, wiring problemss, help pleas?
Discussion in 'Civic and CRX - EF' started by tricktoyz14, Mar 26, 2009.
  1. tricktoyz14
    tricktoyz14 New Member
    strayhorn, MS
    i started a new thread caues the last one got long and drawn out,
    but its a 1989 crx si i put a b18 into out of a 1990 integra,
    the plugs wont fire, and the fuel pump wont come on,
    also there are no lights on the dash at all.
    its a new main relay,
    a good computer, (i put it on my 91 teg and it worked fine)
    and a new fuel pumpp.
    i think my underdash wiring harness may be out.
    or something like that.
    cause i have everything wired up right,
    its just like the computer isnt getting the signal to turn on.
    and i cant get whyy,
    any help is appreciatedd.
  2. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    Fuses? grounds? Posititve to the battery?
  3. tricktoyz14
    strayhorn, MS
    all fuses are good,
    i think i have all the groundss.
    i have alot of places groundedd.
    and the positive to the battery?
    i have it ran to the lil fuse thing under the hood then to the starterr
  4. tricktoyz14
    strayhorn, MS
    that last reply made me sound stupid,
    i have the positive to the battery hooked up to the
    underhood fuse box,
    and then ran to the starter.
    all the fuses are good,
    i stripped my wiring harness back the other day on a ground,
    and the wire inside was coroded.
    i dunno how much of my harness is like this.
    would that be why my computer isnt getting signall?
  5. EnyCrxSiR
    EnyCrxSiR New Member
    yo make sure u got a obd 1 dizzy and p28 computer and buy a step up harness or get your self a pr3 integra ecu if you runnin vtec and run the wires straight to the ecu
  6. jlicrx
    jlicrx Senior Member
    Colorado Springs
    do you have the ground that comes out of the engine harness connected at the thermostat housing? - it is the ground for the ECU, the main relay and most of the sensors - it is on the upper right in the picture with ring connector on the end
  7. INJEN78
    INJEN78 HS LEGEND
    OHIO
    tstat ground will kill you...
  8. tricktoyz14
    strayhorn, MS
    yess i have that ground,
    but when i stripped it back it was coroded in the wiring..
    would that me my problem?
  9. Fernpatch
    Fernpatch Member
    Bellingham,WA
    Fix the coroded wiring at your ground and see what it does. It should work alot better.
  10. tricktoyz14
    strayhorn, MS
    i replaced the whole wire, and still nothing,
  11. INJEN78
    INJEN78 HS LEGEND
    OHIO
    hmmm sounds like you have a ground off somewhere,,,maybe even check the wiring from the battery to the fusepanel..and from the tumbler(where you put the key in)
  12. sneakerfile410
    sneakerfile410 Banned
    Wholesale Brand Watches
    :spam:
  13. yellow88crx
    yellow88crx Member
    check the ground from the side wall to the clutch cable
    [​IMG][​IMG]
