If you are not trying to spend an arm and a leg which motor would you swap into a 89 CRX-SI? I have the shell with no motor, tranny, ecu, or wiring harness.
Well I'd put the original one in with a few special parts put in during the rebuild. You can pick up a D16A6 for $100 or so and build it with $500-1000 (depends on how wild you want to get)
