89 crx w/ jdm b16a
7thgen01
Member
ive got an 89 crx with a jdm b16a in it(obd0) cable tranny. what clutch do i need to put in it, as far as from what vehicle. i need this asap so if you know, please respond,
I believe you can get one for a 99-00 Si civic, not sure though...... I'd take your old clutch setup to the parts store and compare it to that one.
not a cable tranny, 90-91 teg is right
Use the Clutch from a 90 Teg Cable Trans ONLY. Your engine and the 90 Teg have a 25mm Spline Input Shaft which is smaller than the later year Teg Cable Transmissions.
I used an Exedy racing clutch kit PN# 08-804 which includes the Pressure Plate, Disk, release and pilot bearings. This is a great clutch for moderate HP uses. It is reported to be good for up to 230lb ft of torque.
Pappy
