ok i can get a 89 civic hb but its dual port and i know the d16z6 in mulit port and vtec so can any one help me with the wiring and the motor is obd 1 it. Is it a bolt on swap ??????
You need to keep your current tranny, or yuse another 4th gen tranny of your choice. Then you will need to change the drivers side L bracket on the mount. You will need I think the coolant sensor off of the back of your original block.
ok guys the motor is coming out of a 94 del sol si and i can get any wires i need do you guys think if i get the wires from the tower to the ecu the wiring will be plug and play or do you guy think i should add the extra wires another thing the left side mount should be taken from the stock motor and used on the sohc motor thats what i heard help me guyz
The mounts are different between generations and you will have to convert for using a hydrolic clutch. Its not worth it in my opinion. Just get a crx si tranny or a dx or lx sedan tranny, preferably the crx si one.
For the wiring harness just grab the engine harness and adapt the diffent plugs onto your engine.
what in the hell did you just ask? oh wait....i see now- you have no vtec because you either didn't run wires for vtec or you didn't run them correctly- are you using the stock ECU in the car? if so, there is no vtec in that computer, you'll either have to use an RPM dependent switch, or a toggle switch to activate vtec
I meant the car is a obd0 and the motor is obd1 so the p28 will not work and there is no obdo ecu with vtec the only one is the b16a 1 but thats to much for the d16z6
