am doing a mini me have complete head can i use obd1 dizzy with obd0 ecu i know i need obd0 injectors and resistor box but will the obd1 dizzy work on the obd0 ecu?
yes i know i can swap the plugs but will it run with the obd0 ecu and i started an othe thread because i most of it figured out just need the dizzy question figured out thanks for the help
an OBD0 ecu cannot read one of the sensors from the OBD1 dizzy. Something to do with the # of pulses given off by either the CYP sensor or TDC sensor. I forgot exactly what the problem is, but I know it cannot work.
Quoted post[/post]]
