89 hf with d16z6 swap...help needed
Discussion in 'HYBRID -> ED-EF / DA' started by 91whitehatch, Aug 14, 2008.
  1. 91whitehatch
    91whitehatch New Member
    indiana
    i have an 89 ef hatch that we swapped a d16z6 motor and trans into. the axles keep poping out. i used the axles from the 95 civic the motor came from( what i was told). do i need to use stock axles to keep them from poping out again? any help would be greatly appreciated
  2. prpprimo
    prpprimo Hondaholic
    ABQ
    You'll need 88-90 teg axles. The axles from the 95 eg have a different spline count and diameter size from your EF hubs. In all theory they "should" not work at all, let alone pop out. If you do a search you will find detailed info on axles.
    out of curiosity...Did you go with a cable to hydro conversion kit?
  3. 91whitehatch
    indiana
    the trans is still a cable...why would I need axles from an integra? I bought the car with the motor and trans in it....all was told was need to put axles in which I have done but they popped out..i know the motor is from a 95 but not for sure on trans.
  4. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    if your still using the stock ef tranny use your stock axles
  5. 91whitehatch
    indiana
    how can I tell what's trans it is? all I know for sure is that its a 5 speed cable trans and d series ofcourse?
  6. efhondakid
    Akron-Canton, Ohio
    You need the axles that go with your car.
  7. prpprimo
    prpprimo Hondaholic
    ABQ
    what axles did you put in it? Like injen stated, if its an ef cable tranny you just need stock ef axles. Either way, at this point find the mentioned axles.
  8. BoostedHatch
    BoostedHatch get tha fuck out!
    Bossier City, Louisiana
    either way if you look at it if its a cable d series tranny and its a 5 speed its most probably gonna be the stock tranny and all you have to do is go buy stock axles for your year model. 92 and up is hydro tranny.
  9. 91whitehatch
    indiana
    i did find out the trans if from a 91 dx. i do appreciate everyones help. thanks
  10. BoostedHatch
  11. 91whitehatch
    indiana
    one more question will the hubs be the same? i know the car was a standard hatch, will the 91 dx axles still work or will i need to change the hubs? im headed to a junk yard tomorrow to get the last few parts i need and if i need the hubs great time to get them.
  12. BoostedHatch
    you shouldnt need the hubs the only thing i think is diff between the std and dx is the dx only comes with one mirrior and the std comes with 2 so yea.
  13. jlicrx
    jlicrx Senior Member
    Colorado Springs
    DX/Si/LX/EX axles won't work with STD hubs - you either need STD axles or you need to swap the knuckles/hubs for DX/Si/LX and use DX/Si/LX/EX axles
  14. red91efhatch
    red91efhatch New Member
    Albuquerque
    This is correct.
  15. 91whitehatch
    indiana
    if the hubs are still the stock hubs for a 4 speed. then i will have to swap them for the dx hubs. correct me if im wrong but arnt the std hubs 23 spline and the dx are 26. so being that the dx trans would be 26 spline.
  16. prpprimo
    prpprimo Hondaholic
    ABQ
    It is the hub side you should be concerned with. Just keep it easy, find axles for your model car. STD. EF civic.
  17. 91whitehatch
    indiana
    I have been really busy lately but got my problem figured out. The standard 4 speed axles wouldnt work,because of the trans. So i got axles from a dx and had to swap the hubs from a dx also. thanks for the info jlicrx. now if i could just figure out what size of injectors to run i would be happy.
  18. efhondakid
    Akron-Canton, Ohio
    Stock OBDI injectors.
