89 Honda CRX idle problem....
Discussion in 'Civic and CRX - EF' started by Aleaf.CRX, Mar 7, 2008.
  1. Aleaf.CRX
    Aleaf.CRX Hates Cunts!
    I know a lot of people probably ask about this, and I've scanned through the references, but my idle is still really weird. When it starts up first thing everyday, the idle is extremely high, sometimes up to around 2000 rpms. After riding around a bit, it'll drop down, sometimes being normal (or around normal) and sometimes it'll be too low.
    Here's a list of replacements. I have no idea what is wrong with it, but I'll list everything, cuz you never know.
    *Battery
    *Distributor
    *Headgasket x2 (I know this probably doesn't have anything to do with what's wrong)
    *Timing Belt
    *Ignitor Coil
    *Ignition Module
    *Air Filter
    I think that's about it.
    Anyway, any advice is welcome. I'm not looking for someone to tell me exactly what it is, just a little push in the right direction maybe and I can do the rest. Thanks!!!:D:D:D
  2. YBLEGAL
    YBLEGAL Regular Member w/ Cheese
    NW Indiana
    intake manifold gasket
    throttle body gasket
    injector seals
    iacv o-rings
    fitv plunger
    iacv cleaning
    (i forget off hand if it's a carb... ignore whatever isnt relavent)
    and that's all i can think of at the moment
  3. LS_VTEC
    LS_VTEC you get the BRAKE
    NJ
    Coolant problems can cause idle issues. Low coolant levels, inoperative thermostat as well. But your problem is probably a vacuum leak or intake manifold gasket leak. Good luck :thumbsup:
  4. 8ballsin
    8ballsin New Member
    Heidelberg,Germany
    try the MAP senser
  5. tunercrazed
    tunercrazed HS Official Hippie
    Tennessee
    test it by exposing the throttle body and covering the holes. If its the lower hole its most likely something with your AICV if its the upper then a FITV
  6. INJEN78
    INJEN78 HS LEGEND
    OHIO
    bleed the air out of your coolant system..either open the rad. cap and let it run or,,on the the head where the coolant hose goes,,there should be a "nipple" type thing that you loosen..
    if that doesnt do it..check all the vacuum lines,and the connections on the manifold
  7. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    just clean your iacv
  8. Celerity
    Celerity Well-Known Member
    Worst advice ever.
    What is going on with you guys ?!
  9. YBLEGAL
    NW Indiana
  10. tunercrazed
    Tennessee
    I'm being held captive by nazi wookies?
  11. LS_VTEC
    NJ
    You have it backwards. The IACV would be the top hole in the throttle body and the FITV would be the bottom. :)
  12. kemp205
    kemp205 sleeper
    bama
    idle control valve
    throttle position sensor
    cold start valve or
    o2 sensors
  13. tunercrazed
    Tennessee
    lol oh well thanks for straightening that out
  14. Aleaf.CRX
    Cold start valve? I'm assuming it does what it's name indicates, right?
    Because my idle's fucked up, but I noticed after the engine is warmed up, it's pretty mellow for the rest of the day....
    My tachometer is the same. I'm redlining it down to work at like 30-35 mph, but after I park it, or the car warms up, it's fine for the rest of the day.....
  15. kemp205
    kemp205 sleeper
    bama
    If it stops when it warms up then its probably not a vacuum problem but it wouldnt hurt to check hoses for cracks
