89 octane ok for b16?
Discussion in 'General Tech and Maintenance' started by BigBoy, Sep 20, 2005.
  1. BigBoy
    BigBoy Senior Member
    cali 818
    bolt ons and cams, 11:1 compression. Accidentally filled up with 89 today. Should i be worried about anything?
  2. confusatron
    confusatron Senior Member
    Chicago area
    It's okay for a stock B16. I can testify to that. But with all those mods and higher compression, I don't know.
  3. drpenguin
    drpenguin Senior Member
    Salem, Or
    I dont know. just swapped in i couldnt run anything but premium. thats 93 here in oregon. atleast where i go it is. Anythign less and its knocks sputters back fires and the whole schabang
  4. BigBoy
    cali 818
    well the best we get in cali is 91. So far i havent taken it past 4K and everything seems fine.
  5. phunky.buddha
    Dallas / Fort Worth, TX
    If you're worried, you could always drain the tank (plug in the bottom) and fill it back up with 91/93.
  6. drpenguin
    Salem, Or
    Ah take it to 8 grand you pussy you know you want to
  7. BigBoy
    cali 818
    yes very tempting...im just gonna drive around town tonite to empty the gas. I heard draining the plug is not a good idea cause its sometimes hard to plug back in.
  8. confusatron
    Chicago area
    I ran my B16A on 87 octane for about 2 weeks, and had no problems whatsoever. Ran great, good power. When I switched to 93 I thought I noticed a slight difference in power, but nothing like night and day or anything.
  9. nitrous_bob
    nitrous_bob Junior Member
    i sprayed 100 shot on 89 octane and 12* timing on a stock mustang 'vert
    no problems at all.....you can and should try to use lower octane when your able to....like when it's cooler out.
    you make more power as long as your not pinging
  10. cycloneb18c3
    cycloneb18c3 Senior Member
    New Jersey
    I ran 87 in my B16 all the time. I never had it ping or anything. I ran 94 from sunoco and I didnt notice a differnce at all-so screw paying 30 cents more a gallon...ill continue running 87
