will any b-series engine bolt up to another b-series engine's tranny? for instance, if i were to take the b20a5's tranny would it bolt up to a b16a engine?
if you are asking if a b18 or b16 tranny will bolt to a B20A5. the answer is no. and why would you want to do that anyways. the b18, b16, b17 all have rod type shifters. the B20A, B20A5, B21A1 all have cable shifters. not worth the time.
the D16Z6 would be the worst option for a motor. why? because it lacks the torque to move this car. this will cause you to change your driving habbits by pushing that motor harder. in turn giving you really bad gas mileage. lol!
the best bang for your buck with this car is the JDM B21A. it is rated at 147hp and 140ft. lbs. and it doesn't have the FRM sleeves so it won't burn oil if you don't romp on it every chance you get. and if you're lucky enough to get the tranny with it. well it has an LSD. only prob with this is it's an automatic. go figure. otherwise you can do the USDM B21A1. 140hp and 135ft. lbs. but it has the FRM sleeves.
if however you come across a huge sum of money then do the H22A swap. or just buy a new car.
