AceMcguyver
If I put an 89 CRX SI engine and transmission in an 87 SI chassis, will everything bolt up correctly including the axles? I've read I may need to change the trans mount, which is fine since I have one from a 91 CRX that I think has the right alignment, what I'm concerned about is the axles fitting correctly. Is there anything else that needs to be considered? I have all the electricial for the 89 including the ECU and all harnesses. I've heard this is not an easy swap but I already have the engine, all I need is the transmission (I think) to make this work. Any help would be appreciated. I'm trying to get this car on the road as cheaply as possible so I can either use it or sell it.
