89 trans and possible front suspension swap auto to man? 's
hashman
I am going to be swapping my 89 lx from man to auto and was curious if anyone had tips or problems i might run into. Also was wondering how i will be putting the clutch pedal in; if the mount is already there etc.
You should be able to swap the pedal box/assembly over from a manual car pretty easily- or you can cut up a manual setup and add the pedal yourself. Everything else is up to wiring, mounts, cutting a hole for the shifter, running a shift linkage etc. Not too hard, but a bunch of parts to swap over.
