'89 ZC axle question... help needed!
Discussion in 'HYBRID -> ED-EF / DA' started by 90SiZC, Oct 29, 2006.
  1. 90SiZC
    90SiZC Junior Member
    I need a new axle for the drivers side on my '90 Si with '89 ZC.
    The 1990 Integra 5 speed axle would be perfect.... except on the trans end the splines are only cut for 1/2 the distance on the stub. I tried to fit one of those.. no go.
    I need an axle splined the complete way. Is there a different axle to ask for?
    Its a bummer as I needed to get the car together for work on Monday. Now I'll have to bum rides.
    TIA
    Jim
  2. 92CHB
    92CHB Senior Member
    Easthampton, MA
  3. jlicrx
    jlicrx Senior Member
    Colorado Springs
    you need 90-93 Integra driver's side axle - it is splined full length - the passenger side 90-93 Integra axle is only splined part way
  4. 90SiZC
    So do I use the drivers side for both axles? Or use a "set" ie drivers and passenger for replacing what I got?
    TIA
    Jim
  5. 90SiZC
    Ok, picked up the drivers side axle... wrestled it in and so far so good. I owe jlicrx a definite beer or 3... :D
    When I researched the swap in 2000 it was straight forward.. use '90 Teg axles. Somewhere along the way someone insisted it was 2 passenger side... and I guess I'm a dumb *ss for believing them.
    Thanks again for the help!
    Jim
