90-93 Integra Rear Disc, Fit Onto 92 Civic 4Door??
Discussion in 'HYBRID -> EG-EK / DC' started by CReX123, Jul 17, 2005.
  1. CReX123
    CReX123 Senior Member
    I have a whole rear disc setup from a 90-93 Integra. Just wondering if it is possible for me to put this on a 92 Civic 4 Door? Please Let Me KNow, THANKS
  2. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    I'd have to check, but I believe you'd just use the spindles, not the whole trailing arm. Compare them to your Civics. They are removed by four torx bolts, and the main spindle bolt on the inside of the trailing arm. Measure the distances between all the holes, and compare them to your Civic.
  3. RazorRamon
    RazorRamon Member
    I just did this swap about a week ago on my 95 hatch. Everything fits fine.
  4. tmitbyh
    tmitbyh Member
    Sumter, South Carolina
    Do you have a write up or tutorial you used for it by chance? I have a wrecked '92 DA sitting in my garage I picked up cheap just for the rear disks to go on my '95 EJ. Any references would be greatly appreciated. Thank you. :thumbup:
    -JB
  5. RazorRamon
    RazorRamon Member
  6. tmitbyh
    tmitbyh Member
    Excellent. I have the Hazone one already but was not sure if there was one out there for this specific swap. I know one guy had told me there was a thread over on H-T about X brakes fitting on Y car, but could not prove a link for me.
  7. RazorRamon
    RazorRamon Member
    http://honda-tech.com/zerothread?id=152884
  8. tmitbyh
    tmitbyh Member
    :worthy:
    For your eBrake did you use the DA one? What about lines? I plan to just upgrade to SS lines at the same time and was thinking of just getting the '95 Si ones, since they are about the same as the DA rears.
    -JB
  9. RazorRamon
    RazorRamon Member
    I used the DA E-brake cables, they are the same. As for lines, SS would be a good idea, but I used some from a 90 Prelude. They are not a perfect fit but it works.
