90-93 teg brakes on a crx?
Discussion in 'Wheels / Suspension / Tires / Brakes' started by frosty, Aug 13, 2007.
  1. frosty
    frosty Junior Member
    i just bought a 93 integra LS as a parts car and want to do a brake conversion for my rex. its an 89 si and it already has the rear disc conversion. i searched but am still wondering if i have to take the knuckles, spindles, etc. or if just the caliper and rotor will bolt up? any info or links would be great, thanks
  2. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    You'll need the whole knuckle assembly. The only way the calipers and rotors will bolt on is if you have 90-91 EX knuckles.
  3. frosty
    would it be better to get the EX knuckles?
  4. K2e2vin
    Raleigh, NC
    For a EF; they're the best option. They're lighter than DA knuckles, and overall correct geometry/dimension(although not really noticeable vs. the DA knuckles). As of right now, the EX brakes are getting rarer at junkyards so it may be wise to just stick with what you got.
  5. frosty
    hey thanks for your help... last question, if i use the teg knuckles will i have to take the dust rings off the axles/knuckles when i do a swap?
