90 accord h22 swap
Discussion in 'HYBRID -> BA-BB /CA-CD' started by 93jdmegtc, Jan 29, 2009.
  1. 93jdmegtc
    93jdmegtc New Member
    my boy is doing a h22 swap what will i need to do ..
    can i used the axles
    the wiring harness
    and the motor mounts ..>?
  2. DickBswapn
    DickBswapn New Member
    Philly Burbs, PA
    If your "boy" is doing it. You don't need to do anything!
  3. 93jdmegtc
    ok i am helping him with it ...lol but forreal what is needed
  4. Z6CRX
    Z6CRX übber ɐɾuıu etarip
    Pittsburgh, PA
    if you keep the same transmission you do not have to change axles.
    H/F series are very interchangeable. I don't remember whats in the 90 accords. if its not an F you will be needing more things than what i list
    Basically, complete longblock,ecu, and jumper harness or to rewire it to the engine OBD, which will either be OBD1 or OBD2. Double check some write ups to your chassis code to find out all the odds and ends.
  5. drummersteve7
    drummersteve7 Junior Member
    this is correct, even if you change to a H23 or H22 transmission, You still keep the same axles(midshaft, as long as they are good to go.
    as far as motor mounts. ESP has great ones, they even have them if your going automatic to 5spd swap(if this is the case you need to get a different transmission mount but ESP sells them, look for "CB" car model.)
    Explicit Speed Performance
    also check out www.cb7tuner.com
    tons of information in the swap thread.
    I have done several swaps, lemme know if you need anything!
    good luck!
  6. tab
    tab Super Moderator
    Aberdeen, Washington State
    You will use your stock accord harness on the H22, replace what you need to, but the axle setup should work fine. Read my guide.
