90 accord transmission solenoid problem. Help!
drumboy37
So i have a 1990 Accord EX Auto and I looked op the ECU codes for it and it is blinking 8 times which i am told means it is having a problem with solenoid B.
Here is what it does: It starts in 4th and the S light always blinks, I can downshift manually to 1 or 2 however, either is 2nd gear. I can then get going and i shift to D. If I need to replace the Solenoid B how do i do that and where is it located? Detailed help please! Thanks so much in advance!
