90 B16a Turbo Crx Part Out
b16_ef
i have an on-going project that i have given up on, so EVERYTHING is for sale!!
most parts off a 90 CRX DX
all prices OBO
B16a head-sold
Cometic head gasket b16 81.5 mm bore .051" thick 75
B16a block w/ crank fresh out of the machine shop, stock bore, crank std. 250
B16a intake manifold, w/ fuel rail dsm 440 injectors 75
CRX si door panels 100
Door glass 25/each
bare door frames, 25/each (no glass, no door panel)
complete doors 75/each
Hatch w glass, couple small dents and scrapes 50, all glass is good.
KYB AGX struts Front and Rear $300
REVO camber correction kit SOLD
old front strut bar, 15
Kteller Exhaust 2.5 kit W/ flowmaster muffler fit pretty good on my crx, quiet too! $200
Crx Climate control unit OK condition 75
All Rear cargo panels and storage bins 200
dash, not great shape, 20
2 diff aftermarket steering wheels 20/each
steering column, still has key and switch on it 25
misc. interior pieces 5/each
Rear disk brake swap (integra i think) new pads, rotors, and calipers, also comes with 4040 prop valve and 15/16 master cylinder 275
front brake knuckles (drilled and slotted rotors, new pads, new wheel bearings, new upper and lower ball joints) both sides 125
Cargo cover, need repaired 25
2 cargo covers for a hatchback (not CRX) good condition 50/each
88-89 Si Cluster and cover 50
90-91 Si Cluster and cover 50
Turn signal/headlight/wiper switch, w/ rear wiper control 25
Clear w/black background corner and bumper lights 25
FAZE boost gauge, and mech oil press gauge, 50/each
FAZE Big tach, 50
all 3 FAZE gauges 125
5 15" black rota slipstreams, no curb marks 350
2 well used BFG drag radials 50
1 "New" style Azenis sports, 2 "old" style azenis, 95% tread 75/each
Combo deal, all 5 rims with all 5 tires already mounted, 500.
Fenders some dents 20/each
Hood w/ hood pins 50
bumper cover, cut to fit intercooler 20
front end special(hood, fenders, bumper)$75
B-series Axles good condition 50/each
90-93 integra axles and shaft
b-series half shaft 50
Chiped P28 ecu w/o chip and socket 75 w/ chip and socket 110
Walbro 255 Fuel pump SOLD
OBD1 b-series Distributor has OBD0 plug, almost new 100
OBD0 b16 distributor, no plugs. 50
Main wiring harness 100
engine harness for b16 75
complete wiring harness from headlight to taillight, including dash, and engine harness 200
Pm me for pic's of anything
Any thing else you might need, pm me and ask, i might have it
everything needs to go! - reasonable offeres will be consedered. - prices do NOT include shipping.
thanks!
do you still have the fuel pump?...if so what size is it?...pm me and let me know
the head is apart now but i can assemble it if you want
i only need one of your Rotas cause one of mine is really messed up. since you have 5 can you just sell me one.
i have someone right now interested in the whole set.
if that falls through i will let you know.
hey i'm interested in the rywire conv harness, is it for a DX which includes also the necessary mpfi conversion or is it the one for an SI that already has the MPFI, also this is shipped right, thanx.
