90 civic crank sensor
skellagher
Elder Driver
ok i just picked up a 90 hatch std with the a d15b7, 4 speed and all the go slow goodies except it has been multi point swapped i am running a pm6 ecu and its throwing a crank sensor code the distributor is a brand new 91 si dizzy. i guess i jus need to know what wire to look at from the dizzy to the ecu. a rapid response would be seriously appriciated.
crank sensor wires are white wire to C2 and orange wire to C1 on the ecu for a 91 si and the same for a 90 std
it has been mpfi swapped so what pins on the ecu do i run the crank position wires to?
i think i fixed the proble one of the wires that go to the crank sensor from the ecu was being grounded out because there was some exposed wire touching the body of the car. so i electrical taped the exposed area and now im good thanks for the input.
