90 crx b16a first gen swap sputtering problem
mi13ke13
I have the b16a first gen full obd0 swap. I have had the car for quite some time and she just started to sputter. I was reading up in places to find out problem but it is not fixed. People say replace the dizzy and some say replace the ignitor. Well i just wanted to know the cheapest way. It comes up with code 9 and they say it is distributor. Can someone please help!!!!
Most likely dizzy. Get a new one or change out the broken part, either coil or ignitor.
Yeah i have replaced the plugs wired cap and rotor.I do have engine codes and one is a o2 sensor and the others are iacv and something else.it is codes 14,9,and 1. Where is the ignotor. And what can i get that off of to use. Maybe a delsol vtec or integra???
Worse problems now
Well now it got alot worse for me and my Rexy. I was driving down the road and i havent got another dizzy yet to fix the code 9 problem cus i dont know where to get one from for the b16a firt gen engine. I was dirving down the road and i hit second gear up to 8200 rpms and then went to shift and it just kinda shut down like a spark plug wire blew off. But i pulled over and it just completely died right then and there. So i popped the hood and it all looked good. So i had to drive it off the road and when i did that it sonded like it started knocking. But it sputters like i blew the ignitor or just blew the dizzy out. And now it wont start unless i give it gas and it wont stay started. I need help and i need help asap. Its my only car and i work far away. PLEASE HELP!!! thanks.
