90 Crx Gettin hot
Discussion in 'General Tech and Maintenance' started by ryangt, Nov 14, 2004.
  1. ryangt
    ryangt Senior Member
    my 90 rex has the stock d15 no mods or anything its just my commuter, i put an oversized radiatior in it to replce an old broken one the car runs hot or at least the gauge says it is, it runs 3/4 the way up the temp gauge but stays there, the fans work and everything too, it isnt getiing al lthe way hot it just looks to be runnin hot
    any info would be mucho appreciated
    thanks guys
  2. Citizen_Insane
    Citizen_Insane Senior Member
    Minneapolis
    I would double check to make sure you don't have any air in your cooling system....thats what it sounds like to me.
    *edit* I think this because my b16 never gets the temp gauge above 1/2 and I'm using a stock CRX HF radiator.
  3. 94RedSiGal
    94RedSiGal Senior Member
    Massachusetts
    Maybe your thermostat is shot?
  4. ryangt
    how do i check for air, i ran it without the cap on till it was hot to bubble off the excess, is there another trick to it??? i replaced the t-stat also but like i mentioned it isnt overheating it stays at a constant temp of hot about 3/4 the way up the temp gauge
  5. Periculum
    Periculum Senior Member
    Martinez, GA
    I know this is what a manual would say "have you checked to see if the fans are plugged in?" When I changed out mine for an Si radiator, i forgot to plug in one of the fans, but that really didnt affect much considering it was the second fan that almost never comes on.
