I have a 1990 CRX HF with the D15B6 or 1.5l with a manuel Transmission and i am trying to get more out of this car. There is not a lot of selection around my area as far as parts.I am thinking on trying to chip the ECU. I already have installed the following:
cold air intake (2.5 inch)
ss header and 2.5 inch exuast to an N1 burnt tip turbo muffler (open baffel)
10 mm plug wires
NGK V groove spark plugs
new oem distributor cap
new oem rotor bug
short shifter
38mm stering wheel
17 inch alun mag rims
coilovers
top strut braces
black halo headlights
black marker lights
black alteza tail lights
aero dynamic body kit (in progress)
the motor runs a little lean and some times hesitates on take off. it also feels to have verry little power. I have looked into doing a swap but I am having problems finding a suitable engine to use. any suggestions would be greatly apprecieated because I know that some of you gus know what you are doing, unlike me.
10 mm plug wires
new oem rotor bug
short shifter
38mm stering wheel
coilovers
top strut braces
black marker lights
