90 crx si w/ b16a axle wont release
Discussion in 'Civic and CRX - EF' started by Schock3, Nov 29, 2008.
  1. Schock3
    Schock3 Junior Member
    i have a 1990 crx si with a b16a. the driver side axle wont release from the half shaft. ive been trying for an hour and still wont release:mad::confused:
  2. beastseries
    beastseries New Member
    how you been trien to release it
  3. Schock3
    with two flat heads on both sides. also been tryin to shake its out of there and its not budging.
  4. YBLEGAL
    YBLEGAL Regular Member w/ Cheese
    NW Indiana
    keeeeep trying. mine was pretty hard to get out too. I used 2 very long pry-bars
  5. Schock3
    did u take off the half shaft and do it or you did it from underneath?
  6. YBLEGAL
    NW Indiana
    I took the axles apart 1 piece at a time from under the car. This was last when I did my clutch swap.
  7. mikey bottles
    mikey bottles Prof. Bottles
    S. Jersey
    mine is exceptionally difficult as well.. if you have access to a impact hammer and compressor u can do what i did and just give the axle a quick shot with the air hammer.. popped right out
  8. Schock3
    tried the air hammer, pry bars, all kinds of wedges and forks. what i ended up doing was taking apart the new axle and using the part of the axle stuck on the halfshaft and used a big zip tie to hold the boot secure
  9. YBLEGAL
    NW Indiana
    wow that sounds really ghetto. w/e floats ur boat.
