90 crx sunroof
pdqcrx
Member
Have a 90 crx si that the back of the sunroof sits to low when shut. It exposes a crack and leaks awfull when it rains. I think it needs new lines pulled from the pan because I have blown them out and it still leaks inside the rails (follows my antenna wire and drips on the pedals.)(also drips off the hatch shock in the back.) Anyone out there replaced the lines from the pan and adjusted the fit of the sunroof. Thanks for the help.
i know is a old thread but i have replaced my seals and i figured the only thing left to leak is the sunroof. when i shut my doors the back of the sunroof kinda jumps up from i guess the air in side the car. any body know how to fix this
then why did you play undertaker and bring it back from the dead
