thatboatguy
Hi,
I’m new to the forum and looking for help with an intermittent starting problem with my 90 Civic.
When the outside temperature is hot, the car will sometime refuse to start. It does turn over at normal speed.
When I cracked the fuel service port I got only a dribble of fuel even with the key on.
Could this be a main relay problem? Fuel pump? It looks like there are two relays on the fuse block in the passenger compartment. One comes unplugged readily. The other one seems to be stuck or is not meant to be removed.
Any help would be appreciated.
TIA
George
TIA
George
