90 DA No Start!!!!!!HELP
Discussion in 'Integra' started by rufio0306, Jan 13, 2011.
  1. rufio0306
    rufio0306 New Member
    St. Cloud, MN
    I recently purchased a non running 1990 Integra. Car will run like a top if you jump the fuel pump to the plug under the seat! Thinking the PGMFI Relay was bad, I found the test procedure for making sure its working correctly and it is.
    At the plug under the seat, when the key is turned on, there is 3.4 mv of power at the Yellow/Black wire. Tested the fuel pump output wire at the PGMFI Plug and that reads the same(3.4mv), there is no resistance in the relay at all.
    Open to suggestions any help appreciated!!!
